Power Steering Pump Mount Bracket
Old Oct 1, 2022 | 10:34 PM
StingrayFox's Avatar
StingrayFox
2nd Gear
Default Power Steering Pump Mount Bracket
HELP!! I have a ‘76 small block and went to replace the belts only to find the power steering pump mount bracket is missing a few bolts and bent. I want to replace it, however one of the bolts I’m missing, I can’t identify the part 🤦🏼‍♀️. The bolt that is missing is the one the red arrow is pointing to in the picture - what is this?? It’s not part of the mount bracket set and I am going crazy trying to figure this out.
Thanks in advance for any help and for being patient with me - it’s my goal to learn and do this work myself, where I can - so I’m still a novice on engine repair and maintenance
Old Oct 1, 2022 | 11:20 PM
gkull's Avatar
gkull
Typical 3/8th 16 sbc motor mount bolt. The length is something like 1.5 inches. But you can pull out the other to compare
Old Oct 1, 2022 | 11:42 PM
interpon's Avatar
interpon
See post 8 for free manual
https://www.corvetteforum.com/forums...ette-lonk.html
Old Oct 2, 2022 | 12:42 AM
StingrayFox
2nd Gear
Thank you interpon! This is exactly what I needed!
To Power Steering Pump Mount Bracket
