Interior T-Top Center Trim Panel
I have a 1980, with that original panel. Towards the rear, the curved part, where it gets painted black to blend in with rear window surround, it has gotten a bit warped/started to flatten. Not massive, but while I have it apart I’d like to tighten things up, and also some re-dying. I’ll get a picture attached shortly.
I don’t know how it got that way. The car has sat for quite a while and had some minor water leaks. I am assuming some combination of a little moisture, a little sun/heat, and 40+ years of gravity, are to blame.
Before I risk doing more harm than good, does anyone know if you can gently reform that material?
That’s basically what I was thinking, but was going to try a piece of larger conduit as the form to clamp to and get the curve. I’ll give it a shot later this week.
New versions of that piece are nearly $300, so I figure it’s completely worth trying something first!
Thanks,
Pete
