A phenomena I’ve noticed and I would appreciate if someone could explain.
I have cutouts in my exhaust, I can toggle between open header and mufflers.
when the engine is at not ideal timing, about 28 degrees total, there is a noticeable difference in idle quality with cutouts shut versus open.
when open, it’s about 500-550rpm, acting like it’s about to die, shut the cutouts and rpms come up to 600ish and the engine is stable.
In my mind, open headers improves the scavenging ability of the motor. Less backpressure means more exhaust gasses exit and it should run better.
why does providing back pressure seem to help the motor idle?
of note, it is a longer duration cam(292/300) and it is installed 4 degrees delayed.
When you reduce the back pressure, the carb leans out, causing the drop in rpm (and a possible drop in power if you don't richen it up).
I did not think about that, so when scavenging improves, this allows more air to flow into the carb. Since no adjustments are made, still the same amount of fuel, but now more air, so leans it out.
Thanks Lars
I was nervous about the fuel mixture differences with my cutouts, so I installed them right before the muffler so the exhaust travels a decent length either way. The muffler is the only difference. There is a change, but its very minor and no one would notice but me.
Thanks Lars
On the main metering circuit the lean-out is not too bad, although still there, when you open up the exhaust: The main metering circuit uses the Bernoulli effect to pull fuel out of the bowl and out the discharge nozzles, so the more air (mass) goes through the venturi, the more fuel is pulled with it. However, the idle and transition circuits do not use the Bernoulli principle to pull fuel out of the carb - they rely entirely on manifold vacuum to pull fuel out of the carb below the throttle plates - the increased airflow has no effect on the fuel being discharged - it remains unchanged if manifold vacuum is relatively unchanged, so the carb leans out. Since the engine gets most of its fuel from the transition circuit during light throttle cruise, the lean-out effect can be significant when improving exhaust performance, such as when swapping over to headers or installing dual exhaust on a car that had a single exhaust. When upgrading the exhaust you typically want to increase jetting in the carb and richen up the idle mixture.
Lars
On "run what you brung" nights at the local dragstrip, every street driven car with headers has to open them up and make a pass down the drag strip. Most drivers are disappointed when their car starts "shooting ducks" all the way down the strip from running lean.
So Lars,
With ECM/Injector/Knock Sensor motors, does this open headers problem get corrected solely via ECM control measures? Is there enough system variation to control injector pulse and timing?
Lars
As an engineer myself(Electrical though), I appreciate the technical explanation. Thanks Lars!
Engine Masters did a test on cutouts and placement. They pretty much needed a header collector extension in any open header application for best power. They mounted the cutout in various distances and got good results with setups close to the end of the various length extensions but really bad results at the back near the axle.
I have never used a cutout but the episode was worth a watch for sure.
28 degrees all in is 10 degrees too retarded. you are giving away close to half of your full throttle power.
i use nitrous when at the track, and I’m sure you know that when using nitrous it is vital to pull timing out.
the nitrous easily makes up for the lost power of pulling 6 degrees.
when I’m normal street driving I run 36 degrees total
2016 C3 of Year Finalist
If you are running such a big cam why are you running such a low idle....I know it sounds cool but you can run it above 900 and adjust your idle mixture to pull in more fuel and richen up the mixture itself and have a higher vacuum at idle. It will improve your cruise A/FR and give it better street manors and not run lean when you open them up...atleast not as lean
It’s a TH400, 600 in drive about 900 in park. If I made it 900 in drive it’d be over 1200 in park(vac advance timing would make it not a linear change)
I think that would be rough on the trans shifting from park to drive at 1300 rpm.
