My 81 Starting Problem
Old Nov 7, 2022 | 11:59 AM
Carpenter 81's Avatar
Carpenter 81
Navigator
Default My 81 Starting Problem
I have a part time issue starting my stock 81 C3. Sometimes I have to move the shift leaver back and forth with the key off to get it to engage and start. If not I have nothing, no noise or buzzer. I am baffled as it cranks right up after moving the shifter back and forth between park and low 1. Sometimes it takes a couple of times doing it other times it cranks right up. I am confident that someone here can steer me in the right direction. Thanks in advance.
Old Nov 7, 2022 | 12:26 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
neutral safety switch
Old Nov 8, 2022 | 06:50 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Yup, agreed. You need to pull the sides off your console and adjust the neutral safety switch.
You do have a factory service manual?
Don't you?
Old Nov 9, 2022 | 01:30 PM
Carpenter 81
Navigator
Old Nov 9, 2022 | 01:33 PM
Carpenter 81
Navigator
I do not have one yet but I am going to order 1 today. Thanks for the advice.
Old Nov 9, 2022 | 02:15 PM
BKarol's Avatar
BKarol
Something to read in the meanwhile. Great write up and pics by Mooser. Don't know if it changed much in 81.
https://www.corvetteforum.com/forums...something.html
To My 81 Starting Problem
