Control arms
Old Nov 7, 2022 | 07:32 PM
Golferdad's Avatar
Golferdad
Default Control arms
I’m pulling the stock engine next week,and putting in comp ex268h cam in,and thought this would be a good time to either repair or replace my upper and lower control arms,the ones on here now 82k on car,so they are pretty worn,what’s the best as for handling,don’t care if it’s stock,or aftermarket,and I’ve heard and seen horror stories of taking these bushing out of a 40 year car,or is it just better to buy a new pair.
Old Nov 7, 2022 | 08:43 PM
kanvasman's Avatar
kanvasman
On my 78 I managed to get the old bushings out with a little work and then I replaced them with the red plastic ones without any issues. Put the engine back in and fast forward a few years to when I was actually getting ready to drive the thing. I tried to get my castor/camber correct and couldn’t come close. At the end of the story I ended up buying a new set of UCA with delran(i think that was what they were called) bushings installed. They also had about 4 or 5 degrees of camber built into them so I didn’thave to shim out too much. Basically it was one side giving me problems most likely the result of a bad crash on that side a long time ago. The lesson learned, for me anyway, was I should have done that the first time. It was not fun doing it with the engine in place. Actually the engine wasn’t the problem but rather the dual elec fan shroud that got in my was. If you know the history of the car and know it was aligned properly, count the shims at each location on the arms. If not, get new ones of some type since none of these cars can get good alignment without some help.
Old Nov 8, 2022 | 08:29 AM
Radovette's Avatar
Radovette
Default My experience on a 78
Easy enough to push the old bushings out. I had problems pressing the new rubber bushings in. Tried making a spacer to keep from distorting the arms while pressing in the new bushings but failed. Ended up taking them to the local Vette shop which had a good jig and spare arms to ensure everything was true. Best money I spent since I know the car was mashed in the front before I got it.
Old Nov 8, 2022 | 09:18 AM
Stormin_Normin's Avatar
Stormin_Normin
After doing one on my 77, I had a local machine shop do the rest for ~$100. Worth every penny.
Old Nov 8, 2022 | 09:19 AM
interpon's Avatar
interpon
air chisel.. mine here with advice
https://www.corvetteforum.com/forums...rs-method.html
Old Nov 8, 2022 | 10:01 PM
Bikespace's Avatar
Bikespace
I had a local garage remove my old LCA bushings, but I was able to push in new poly bushings. For the UCAs, I switched to SPC adjustables. Much easier to get lots of caster that way.
For a "while I was in there" punchcard, consider:
Replace/refresh radiator
Remove shroud, convert to electric fans
Add spreader bar
Lots of wire wheel and painting
To Control arms
