Rod Cap OK to use?
Old Nov 20, 2022 | 04:27 PM
Kirk H's Avatar
Kirk H
Default Rod Cap OK to use?
Assembling L-36 and while attaching a connecting rod cap, I accidentally nicked the bearing and cap itself. I have replaced the bearing but I'd like to know if there is an issue with using the rod cap. The nick (small gouge) was at the top edge, about 1/4" in from the side. I could feel it so I gently filed the edge until I couldn't feel it anymore. This created a tiny bevel which I think is visible in the attached pic. Does anyone think this will pose a problem with either letting oil in behind the bearing or exposing it to possible spinning?
About 1/4" down from the inside top edge you can see where the small gouge was, along with a slight bevel created by the file. It feels smooth and is not detectible with a fingernail.
Old Nov 20, 2022 | 04:37 PM
1Hotrodz's Avatar
1Hotrodz
Honestly don't think you will have any problems there. You could put the rod end and cap together and torque to spec and check for "out of round" in four locations equally spaced apart using a T or snap gauge and a 1-2" micrometer. Good Luck!
Old Nov 20, 2022 | 05:18 PM
Kirk H's Avatar
Kirk H
Thanks 1 Hotrodz for your input. I imagine I could use my dial bore gauge to check for roundness as well. I was more concerned with the nick causing a problem with the bearing staying put or oil getting behind the shell because of the bevel and slight nick (which is below surface now).
Old Nov 20, 2022 | 05:28 PM
1Hotrodz's Avatar
1Hotrodz
You are welcome! Does your dial bore gauge go down that small, mine does not? If it does then use that to check for out of round. And the nick should not be a problem. the bearing shells have tangs on the ends to keep from spinning. I've heard some builders will use loctite on the bearing shells to keep them in place, but doing that will decrease the bearing to journal clearance. Not a big fan of that, but thought I would mention it.
Old Nov 20, 2022 | 06:05 PM
Kirk H's Avatar
Kirk H
So my bore gauge goes down to .7"- 1.5" with smallest fitting but I'll be using the 2" -6" attachment since the bore (without shell) is around 2 and 5/16". Should I check for roundness with shell out, shell in, or both? I've never had to do this before since all parts are original and the machinist has always checked this when doing the rod work. I've had this car for over 35 years now and have rebuilt the motor twice.
Thanks again for your input- I always know there are members with far more experience and "know how" for when I get into spots like this!
Old Nov 20, 2022 | 11:17 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Just file it 'till it's smooth and it won't be an issue at all. As long as there isn't anything pressing in on the bearing shell you'll be fine.
JIM
Old Nov 21, 2022 | 09:16 AM
7t9l82's Avatar
7t9l82
I take a file and gently smooth out sharp edges anyway so I don't see a problem . I doubt you have an out of round condition..
Old Nov 21, 2022 | 03:56 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Looks fine...just replace all the bolts with ARPs so you dont snap and old one when torquing them
Old Nov 21, 2022 | 08:14 PM
Stormin_Normin's Avatar
Stormin_Normin
JIM
^ this , as long as the surface is flat it's fine.
Old Nov 21, 2022 | 10:37 PM
derekderek's Avatar
derekderek
JIM
and jim puts a lot more stress on connecting rods than most of us.
Old Nov 22, 2022 | 03:50 PM
Roy W.'s Avatar
Roy W.
Disabled by request 8 JUN 2025
I use a sheet of wet and dry paper on a sheet of glass. A couple of passes over the wet and dry paper will take care of any nicks.
Old Nov 24, 2022 | 09:57 PM
1Hotrodz's Avatar
1Hotrodz
Tq. rod bolts to spec and check for runout with shell out.
To Rod Cap OK to use?
