Crate motor experiences
Old Nov 25, 2022 | 05:52 PM
derekderek's Avatar
derekderek
we try to stay away from "how much you got?". you can't do install yourself? do you have somebody local that can do it? have you discussed this with him? both price and time frame?
Old Nov 25, 2022 | 06:02 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
Originally Posted by 0311 jarhead
Be careful with buying an engine with Vortech heads. Your intake choices are limited and I couldnt find
one that would work correctly under my 72 L48 hood. Maybe someone else has but I think I've looked
at all options.
My L31 vortec engine fits with a stock air cleaner. I used a Cyclone intake manifold
Old Nov 25, 2022 | 06:24 PM
509 rat's Avatar
509 rat
Default yes
Originally Posted by 68hemi
Yeah, that SB 396 sounds like a really good engine but I don’t think the OP has a desire for that kind of power or wants to spend that kind of money. Not all of us are power mongers like me.
Old Nov 25, 2022 | 06:33 PM
twa1457's Avatar
twa1457
Appreciate your money stance, it is a limiting factor however. Anyway, dont have a lift or patience to do myself along with being
in my mid 60's dont do well crawling under cars anymore.
Old Nov 25, 2022 | 07:34 PM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
What carb? Do you know what the carb pad height is? I'm still about a 1/4" too tall with a Speedmaster intake and Qjet and can get a stock air cleaner with a 2" elemant in, but it still just hits and the ZZ383 is starving for air.
Old Nov 25, 2022 | 08:03 PM
derekderek's Avatar
derekderek
i don't think he is settled in on the intake yet. the one blueprint supplies if he goes that route may be too tall. his iron 73 L48 intake is too old and ugly, although it fits and aluminum paint can work wonders. an eddy performer-NON rpm works well and doesn't really give anything up to the RPM or the air gap. the 80 L82 intake is aluminum and works well. and can usually be found reasonable. example. https://www.ebay.com/itm/13421944400...RoCP-4QAvD_BwE
Old Nov 25, 2022 | 11:04 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
Quadrajet carb, the height is 4.25
https://www.summitracing.com/parts/pfs-52007
Old Nov 26, 2022 | 01:28 PM
509 rat's Avatar
509 rat
Default vacuum
Originally Posted by 71 Vert LS1
I wonder if Blueprint would put in a smaller cam in the 396 and have a super fun torque monster with enough vacuum to run power brakes?
How much vacuum do you need I am pretty sure that motor will make enough for you, you can call them and ask I have a stout 434 that rips *** and has enough vacuum to run my head lights and wiper door .
