Crate motor experiences
Old Nov 21, 2022 | 12:29 PM
twa1457's Avatar
twa1457
Default Crate motor experiences
Shopping for my 73 can i get some shares on what works, what doesnt, recommendations for small block drop in ready 300hp+ with no
clearance issues with the hood.
Old Nov 22, 2022 | 04:15 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Yet another "Will it clear the stock hood" Thread!
Any gen 1 Small block will drop right in. What makes it clear the factory hood or not isn't the engine.
It's the intake manifold. Stick with a base Edelbrock performer manifold and you will be fine.
Or just swap out your original intake manifold.
Or, buy a taller hood!
Old Nov 22, 2022 | 06:03 AM
derekderek's Avatar
derekderek
crate motor used to mean new in a crate from GM OE engine. now just about every rebuilt by anybody with a set of wrenches is called a crate motor. looks like the days of 2500 dollar new engines from radley chevy on ebay are over. blueprint and skip white both have good reps. the rebuilder down the street from you? we can't tell from here. what city are you in? people can maybe point you towards or away from local people.
but as 4-vettes said, any gen 1 small block will take your intake and water pump, etc and sit on your mounts and attach to your trans. 383 needs the correct flywheel or flex plate and balancer for the way it is balanced. Vortec engine need oddball intake that could cause clearance problems and many do not take mech fuel pump. why do you feel your current engine needs replaced?
Old Nov 22, 2022 | 01:31 PM
wwiiavfan's Avatar
wwiiavfan
Correct. Stock intakes aren't crap, they just leave a few horsepower on the table. probably not enough for you to even notice.
Old Nov 23, 2022 | 11:11 AM
7t9l82's Avatar
7t9l82
Will an upgraded intake give you an extra hundred horsepower? No it won't. On a stock rebuild a aftermarket intake won't give you much, however, on an engine with more cam better flowing heads and more compression an after market intake will likely give you more than aittle extra power.
Old Nov 23, 2022 | 11:20 AM
augiedoggy's Avatar
augiedoggy
the standard edelbrock performer fits... the performer RPM and air gap are the taller intakes (when it comes to edelbrock brand.) many of the chinese clones sold under various brands are like .5-3/4 on an inch shorter I believe.
I have a taller hood so I run a assault RPM clone with a 1" tapered spacer on it.
Old Nov 23, 2022 | 12:17 PM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
Be careful with buying an engine with Vortech heads. Your intake choices are limited and I couldnt find
one that would work correctly under my 72 L48 hood. Maybe someone else has but I think I've looked
at all options.
Old Nov 23, 2022 | 12:27 PM
Bikespace's Avatar
Bikespace
You probably won't notice. But if you are putting in a new, clean crate motor, you will notice the filthy, heavy iron intake. There are other low-profile aluminum spread-bore intakes that you can use, if the high-rise single-plane ZZ6 intake doesn't fit under your hood (for example).
Old Nov 23, 2022 | 12:46 PM
twa1457's Avatar
twa1457
Lots of info here thanks. Im told Chevypermance motors are not gen 1 motors and you must use thier components if not buying a run ready
unit. Also thier Vortec heads along with aluminum Blueprint motors heads may have issues with gen 1 headers which is ok but what headers work on these with no issues. The Eldobrock performer intake is fine for clearence but on a Stroker application i would expect to lose some HP.
Dont know if that will rule out a stroker, which is what i really want to do. Hey folks just trying to get some tips here before i buy.
carry on.......
Old Nov 24, 2022 | 08:07 AM
derekderek's Avatar
derekderek
what is wrong with the current, paid-for engine? how many miles on it? is it still numbers-matching?
Old Nov 24, 2022 | 01:17 PM
twa1457's Avatar
twa1457
Numbers match 93k miles. Base 350 withsome bolt on upgrades, have all stock components. PS PB AC 4 spd. Engine has some oil leaks occasional running
issues typical. Thinking stroker motor to make a beast, not sure if keeping it matching is going to add enough value to rebuild instead, it is
very nice piece with a restore done in 2012 to the car and chasis only.
Old Nov 24, 2022 | 01:59 PM
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
All true. Local machine shops can’t compete with places like Blueprint but they are into building big h.p. examples. If you are looking for a simple 300 h.p. engine there doesn’t seem to be a lot of choices. You would probably be better off finding someone that is restomod in a car and has a perfectly good engine they are replacing.
Old Nov 24, 2022 | 03:12 PM
509 rat's Avatar
509 rat
Default a beast
What would your beast be as in hp wise 450 to 550 I would look at blue print motors 50.000 mile warranty have your choice of power plants .
Old Nov 24, 2022 | 03:40 PM
twa1457's Avatar
twa1457
Probably going to go with the Blueprint 355 longblock. Seems to be a good value, good reviews.
Old Nov 24, 2022 | 04:48 PM
derekderek's Avatar
derekderek
funny that the 4100 buck long block comes with cast steel crank and the 4200 buck one is cast iron. go up to the dressed engine for 47 and change and you get forged steel crank and an intake and carb you can sell...
Old Nov 24, 2022 | 06:18 PM
twa1457's Avatar
twa1457
Good catch on the crank 10-4 there. Yeah could sell the intake and carb i wont need, thanks
Old Nov 25, 2022 | 03:48 PM
509 rat's Avatar
509 rat
Default the beast
I would sat that 355 is way shy of a beast but if you can I would at least go with the 396 small block it has a 110 lobe sep that you and your buddies will die for, there is a guy at a local car show event that I see a lot has it in a 72 and loves it and it sounds and runs great .
To Crate motor experiences
Old Nov 25, 2022 | 04:40 PM
68hemi's Avatar
68hemi
Yeah, that SB 396 sounds like a really good engine but I don’t think the OP has a desire for that kind of power or wants to spend that kind of money. Not all of us are power mongers like me.
Old Nov 25, 2022 | 05:27 PM
71 Vert LS1's Avatar
71 Vert LS1
I wonder if Blueprint would put in a smaller cam in the 396 and have a super fun torque monster with enough vacuum to run power brakes?
Old Nov 25, 2022 | 05:38 PM
twa1457's Avatar
twa1457
No one has asked what I wanted to spend on this project. Looking to spend $10K including installation.
