Head replacment recommendations
Old Dec 12, 2022 | 04:30 PM
REELAV8R's Avatar
REELAV8R
Originally Posted by BOOT77
A lot of modern heads are pretty good n better with a bit of work. For street mild stuff I suggest small runners like 180ish and if you can tune and want to be more racey then 200cc The NEW version of the Dart SHP 180 is nice and one of the better out of the box ready to go heads, 64cc tho the bigger 72cc they sink the valves to make the chamber larger. AFR(Enforcers) is the best version of the generic ebay 200cc castings in my opinion But their VJ n such favors larger cams. Trickflow or Speedway Motors have camel hump versions if you wanna have some modern head advantages(design) but retain classic look.
Actually considering buying a set of the Summit iron heads for my truck project BUCK cause I'm tired of trying to find decent used vortecs. Summit heads are Dart S/S-iron eagles basically.
https://youtu.be/42R26b6_sjg
why is it Dart only tells you flow at one opening height, presumably the best flow? No mention of test conditions or bore size, very lean on info here.
I have a set of the origional Dart SHP’s. Disappointing to say the least. Quality was mediocre to poor. For the same money you can do a lot better elsewhere I bet.
Old Dec 12, 2022 | 05:33 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
THis is a pretty good list last updated in 2018. the manufacturers part number lists the part adn the person who did the flow data
http://www.users.interport.net/s/r/s...ehdc.htm#Chevy
pretty good info and lots of heads
Old Dec 12, 2022 | 06:09 PM
BOOT77's Avatar
BOOT77
Maybe because they know people only care about that idk, I don't care bout flow numbers myself But more so the shape. Think I saw a full flow list someplace for them but again not my main concern for heads.
Quality well I covered that...
Old Dec 12, 2022 | 06:35 PM
Rescue Rogers
Flow numbers are kind of a big deal
They are a good way to compare heads knowing that the AFRs are about the best out there and comparing flow to them. Other than that you are just going by how pretty they are
Old Dec 12, 2022 | 06:58 PM
BOOT77's Avatar
BOOT77
http://speed.academy/10-myths-of-cyl...HPjJmDjB0qNbhc
Old Dec 12, 2022 | 06:59 PM
NewbVetteGuy's Avatar
NewbVetteGuy
If you can get enough compression for what you want (the Felpro .015" shim gasket helps, if you deck is perfectly flat), the ATK 70cc/185cc heads should definitely be considered.
They definitely have the best best flow for the size for under $1,050.
https://www.high-performance-engines...p/sbc70185.htm
They're the Profiler (Cast in Ohio) heads, but they dropped the 64cc chamber version or sold out of them; this is a version with standard height exhaust ports so they fit most headers well. (They're the casting that Chad Speier is using in his S-Factor street lineup, but he CNCs them to at least 205cc.)
They only come with hyd roller springs, but you could swap them over to other springs yourself or give ATK a call and see if they'd send you a set with flat tappet appropriate springs (not that that's the best way to buy / spec valve springs...).
Adam
P.S. Boot: Good to see you on CF! (I usually see you post on ST and your YouTube videos, only.)
Old Dec 12, 2022 | 07:04 PM
BOOT77's Avatar
BOOT77
Originally Posted by NewbVetteGuy
Adam
You should look harder I'm on several boards and have been for a Long time! Also I post A LOT more than just my vids, post/reply to subjects same as I always have before I made vids. Now I also make vid post when relevant, even vids that aren't mine.
Old Dec 12, 2022 | 07:12 PM
Rescue Rogers
he contradicts himself a couple of times but the best is # 10 port shape contradicts what he says about #6 flow testing..... He doe make a lot of absolute statements of all these things being bad but never says why they are all important....sounds like he likes imports too. The biggest thing he doesnt touch on well enough is the flow at lower valve openning numbers. You are below 5000 rpm alot and the flow down low will help move the air into the cylinders when you need it, not just at max lift. The biggest example of the importance of a free flowing head is in a engine masters episode where they gain 90HP just from porting the heads to increase flow....They also have episodes on swapping heads out for bigger ports and more flow and show that too big can be the same as too small.
Old Dec 12, 2022 | 07:25 PM
BOOT77's Avatar
BOOT77
Nobody gets it 100% right because there are too many different scenarios, that's why they call it experience. You developed what you need for your app
Engine masters have messed up more than a few times in their test, some are pretty good but see my first sentence.
Old Dec 12, 2022 | 07:28 PM
BOOT77's Avatar
BOOT77
Just posted this the other day on a muffler thread, been in my YT favs for awhile but it's kinda relevant here. As they say in porting threads, a sewer pipe flows A LOT!
Old Dec 12, 2022 | 08:23 PM
Rescue Rogers
ya i know..Ive watched your videos
Old Dec 12, 2022 | 10:55 PM
Stormin_Normin's Avatar
Stormin_Normin
Adam
If those heads really flow like advertised, those are some pretty decent numbers. I'd like to see someone flow those and compare numbers, a lot of advertised numbers turn out to be BS. AFR, Dart, Brodix, all seem to be pretty close, others not even in the ballpark.
Old Dec 13, 2022 | 07:20 AM
  #33
REELAV8R's Avatar
REELAV8R
I'm sorry, "shape"?
As in shape of the port. THAT would be flow would it not? If flow is not relevant.....then what is?
Obviously quality is, but on an apples to apples comparison flow is king.
Old Dec 13, 2022 | 09:24 AM
  #34
augiedoggy's Avatar
augiedoggy
Key is better flow throughout the whole lift range and not just better flow at say .600 at the cost of flow below that. This is where companies like AFR shine. better flow at lower lift number allows larger heads to work well even on smaller displacement engines.
they accomplish this through the port design
Old Dec 13, 2022 | 09:47 AM
  #35
BOOT77's Avatar
BOOT77
Thx for your support and watching, don't forget to like comment and subscribe
Old Dec 13, 2022 | 09:49 AM
  #36
BOOT77's Avatar
BOOT77
I'm sorry, "shape"?
There are things that hurt flow a bit but help power
Old Dec 13, 2022 | 10:09 AM
  #37
Eric P's Avatar
Eric P
Originally Posted by twa1457
Have 73 base 350 motor needs head work, what replacement heads are out there that would work well with dual plane intake, 600cfm Eldobrock carb, headers, HEI ign alrady on it without breaking the bank?
I went with these 183 cc intake port , beautiful looking heads that don't break the bank and has good hardware and nice flow numbers
Maxx 183 SBC (Sold in Pairs) - PROMAXX Performance Products
To Head replacment recommendations
Old Dec 13, 2022 | 11:06 AM
  #38
REELAV8R's Avatar
REELAV8R
Your statements are vague at best. What exactly are you referring to? Power as in HP? Power as in torque? Be specific. Where in the RPM range are we talking? We are still talking about HEAD flow correct? Are you inferring that if I can flow less air and fuel into the cylinder I can make more power?
Being coy is not productive.
Old Dec 13, 2022 | 11:35 AM
  #39
BOOT77's Avatar
BOOT77
I hear Google is very useful
Old Dec 13, 2022 | 01:12 PM
  #40
REELAV8R's Avatar
REELAV8R
Are your contributing or What is that? You tube arrogance?
If you want to contribute, that's great. If you want to pretend you're superior by throwing around vague comments that kind of hint...something? Well I'm sure there are folks who are impressed by that.
