Hey guys, have an 82 with 66k original miles. Having a hi idle issue currently. Check the tps today and it was at 511, played with it for a while and got it to 526, as you know every time you tighten the dam screws the reading changes. Checked for vacuum leaks and any disconnected hoses including under the air cleaner and everything looked good. Neither of these fixed to hi idle, 1400 at start up and never goes down. I did change the temp sensor on the front of the manifold a few years back. Took the car for a ride and noticed I had low heat coming out of the blower, took a look at the temp gauge and it had barely moved even after 20 miles. Now during the summer I had done a rad flush and replaced the thermostat with a failsafe model. Checked coolant levels in the rad and overflow tank and both looked good. Could the thermostat be stuck open and because im not ever warming up the computer is keeping the idle hi? Thanks in advance.... Cory originally put this in the 82 sticky but no answers so I am trying here.
There's is a relationship between coolant temperature and IAC counts. A scanner would be able to tell you if the coolant temperature too low or a vacuum leak by the IAC counts.
Pardon my ignorance but what type of scanner? I mean I can hold the radiator hose in my hand after twenty minutes of driving with no issues getting burned.
An OBD1 scanner. It allows you to see the data that the ECM is seeing. You can see Coolant temperature and you can also see the IAC counts. let's say that the IAC count is zero at 1400 RPM's with the throttle closed and coolant temperature at 195 which would point in the direction of a vacuum leak. A smoker is the best way to find leaks and with C3's there's no shortage of them. If you're seeing a lower than normal coolant temperature the ECM is going to command a higher IAC count. Every CFI owner should have a scan tool along with other EFI test equipment. Even if you can't interpret the data there are others that can and not every EFI issue it going to have a code.
