Engine won't rev and makes no power!
First thing we did was set the timing, which my assumption was it would be way off: it was around 18 degrees all in! I set it at 34 total and that gave it 20 initial, which helped the running and idle. We went and drove it: Still a PIG!
While driving it we thought it felt like the secondaries wouldn't open. Came back home and revved it, saw they wouldn't open. Checked them for operation, and they were good. So put in the lightest spring for the secondaries, and went and drove it: no change.
It doesn't smell like it's rich, but won't know if the fueling it good until we put the wideband on next and tune the carb. When you shift from idle to gear, there's a big drop in RPM (from 1000 to 600)... This makes me think this big cam is trying to fight a stock torque converter!
So we have a car that feels like it makes 100HP, won't rev past 3500RPM, and is a total PIG. I'm scared it's way over cammed, stock converter, and highway gears. I don't have the specs on anything, so no way to confirm. If this is the case, wouldn't I still be able to rev the engine up to the 5500 redline?
Next steps are wide band to ensure the carb is tuned correctly, what else could be causing this massive loss of power? What should we work through next? It runs great at idle and low RPM cruise, but when you step on it nothing happens lol
check park vacuum versus drive vacuum, I bet there’s a noticeable difference.
Which in turns pulls timing, compounding the problem.
you could test it by just disconnecting the vac advance and seeing if that resolves the rpm drop. If it does, then the solution would be a vac adv can that’s “all in” at a lower vacuum
Check the compression and let us know how bad it is. If it's really bad that could be your whole problem.
Good insight, this slipped my mind because everything I own has a manual!
This is correct, for some reason, someone spent a bunch of money on this car and built a 305 HO! It has the 416 heads, a big cam, a Weiand intake, headers, and a 670 Street Avenger Holley. We don't know the specs on any of it, but it runs horribly! It's my step dad's car, who taught me everything I know about wrenching so, i've got to get it sorted for him.
https://www.youtube.com/shorts/VwH6JmkptAk
Is the cam too big for a low compression engine? Did someone install a big cam with stock springs and are we getting valve float?
Maybe that was the intended goal for whoever was building it.
slap a wieland 144 on there! Lol
You need to take post # 8 very seriously before tearing things apart.
Later model C3s IGN & FUEL systems need a brain to tell them what to do at every RPM. Without that data available to feed those two, the engine will run like yours is doing now.
Might be a good time to go old school carb and distributor.
