Wiper Vacuum Relay Mount
Old Jan 15, 2023 | 01:51 PM
Greentension's Avatar
Greentension
Default Wiper Vacuum Relay Mount
So I have to reinstall the wiper door vacuum relay mount onto the fire wall. I know that at some point in 69, they moved the location of the valve for some reason. What I need to know is which is the preferred location. More forward or more rearward. Mine originally was forward.
Thanks again for every ones help.
Old Jan 16, 2023 | 07:25 AM
Greentension
I seem to remember reading something about hood clearance..
Old Jan 16, 2023 | 02:40 PM
robertea's Avatar
robertea
I think most were mounted up near the master cylinder. At some point they moved some of them to the passenger side, but my 427 with Air there is not much room over there.
Also, if you moved the mounting location the original hoses would not fit.
Old Jan 16, 2023 | 05:30 PM
Greentension
That's a great picture .This helps out a lot. From the looks of the mounting holes in my firewall, that's where mine should go but I see a lot of them set back about 3 inches from there.
Old Jan 16, 2023 | 06:00 PM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Mine is down below the ac it’s visible through the lower grills.
Old Jan 16, 2023 | 08:32 PM
C3 Stroker's Avatar
C3 Stroker
That's exactly like on my '69. It's removed now, since I've converted to an electric wiper door.
To Wiper Vacuum Relay Mount
