1970 - thermostat missing?
Old Jan 21, 2023 | 02:41 PM
reedyfork's Avatar
reedyfork
Default 1970 - thermostat missing?
I have only had my 1970 L46 for a couple months now, but enough time to take it out for three good drives (city, highway, and country roads). I have a few issues that I've discovered I need help/advice on, and will post them separately:
#1. The temperature gauge does not work, so I planned to systematically replace the easy things first (thermostat, sending unit, sending unit lead, etc.). I'm pretty sure the sending unit lead is the issue (the wire appears to be just hanging on by a thread), but I had already bought the $16 thermostat and decided to switch it out anyway... I removed the housing to find no thermostat at all! Is there any situation at all where there would not be a thermostat, or some form of a thermostat installed somewhere else I'm not aware of?
My only guess here is that someone removed it as a "safety measure" to try and avoid possible unknown overheating since the temp gauge did not work (rather than fixing the issue with the temp gauge?). Any other thoughts?
Old Jan 21, 2023 | 03:05 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
hmm, could be but also hot running motor bandaid.
does it use coolant?
Old Jan 21, 2023 | 03:13 PM
HeadsU.P.'s Avatar
HeadsU.P.
That is a misconception that still goes on today that the engine will run cooler w/o the T-Stat. In some cases, it actually ran hotter, but whatever.
Don't know what type / brand waterneck gasket you plan on installing but I have had excellent luck with Permatex Waterneck / Waterpump RTV. Found at Autozone, small white tube. It is glycol proof, where some sealants are not.
Another tip is to remove that upper Rad Hose and take the waterneck over to your belt sander. You need to roughen up the chrome to get a good seal with the hose.
And again, use a RTV on the hose also. Let everything dry overnite.
The temp sender could be faulty or oily spade connector or bad wiring. If you end up removing the sender, never use a sealant or tape over the entire threads, only part way. The sender needs to GRD itself on a "one-wire system".
Old Jan 21, 2023 | 03:23 PM
71 Green 454's Avatar
71 Green 454
That's one heck of a throttle return spring!
Old Jan 21, 2023 | 03:45 PM
reedyfork's Avatar
reedyfork
As far as I can tell in the limited time I've had so far, it does not appear to be using or leaking coolant.
Old Jan 21, 2023 | 03:51 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
good.
do you have a harbor freight temp gun?
you can verify what is going on.
Old Jan 21, 2023 | 04:02 PM
HeadsU.P.'s Avatar
HeadsU.P.
One other tip on those waternecks reedyfork
Whether its aluminum, cast iron, billet, bling chrome, take the two bolts you plan on using and place them in the respective holes. Just snug them by hand.
Now slide your waterneck over next to the bolts. The bolt head must be lower than the bosses.
You would be surprised how many people bottom out those bolts then the housing leaks.
Old Jan 21, 2023 | 04:37 PM
Avispa's Avatar
Avispa
Reedy, yes you need a thermostat in there and no there isn't any other one in the cooling system.
Heads, I had to read what you posted a few times to figure out what you meant. You're right. It just read kind of strange. What he means is hand thread the water outlet bolts into the intake manifold as far as they will go, then put the water outlet NEXT to the bolts with the outlet leveled on the thermostat hole You can't slide the outlet over the bolt heads. Yes, the bolt heads have to be lower than the bolt bosses on the outlet to be sure the bolts won't bottom out before they clamp the outlet in place.
Old Jan 22, 2023 | 08:02 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Thermostats are there for a reason. That is to bring the engine to operating temp (thermostat rating) asap. Running an engine too cold can create damage caused by sludge (condensation in oil).
Old Jan 22, 2023 | 09:20 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
it was probably running hot or the owner thought so. read through these to test your gauge...if the sender is mismatched you will get improper readings http://repairs.willcoxcorvette.com/?...&s=temperature
Old Jan 22, 2023 | 10:03 AM
derekderek's Avatar
derekderek
there s one valid reason to find no thermostat under the gooseneck. Bubba was here!! and drop the bling gooseneck on a piece of sandpaper and get the plating off the base.where it seals to the gasket.
Old Jan 22, 2023 | 10:17 AM
REELAV8R's Avatar
REELAV8R
Before you install you're new thermostat. Put it in a pot of water on the stove and heat it up. Insure that it opens, and opens at the rated temperature. A 180 thermostat is a good place to be. With the quality you get these days I would not trust any thermostat before testing it.
Another consideration is the robert shaw/ parallel flow thermostat. Much superior to coolant flow vs the standard type thermostat.
Amazon Amazon
Keep in mind the temp rating is merely the lowest temperature the coolant will achieve. It will likely run higher than the thermostat rated temp under many conditions.
Old Jan 22, 2023 | 10:34 AM
Mdbirk's Avatar
Mdbirk
Running no thermostat is an old race car secret...weight reduction!
Old Jan 22, 2023 | 11:00 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
reedyfork, testing is always good advice for thermostats (and heater cores (BTDT)) --- plus understand that these are not precision devices. Beginning to open will likely occur within 5°F +/- of the rating with fully open 20-30°F above the rating.
Reelav8r, as you know, a lot of folks think an engine will maintain whatever temp the thermostat rating is, which is why they think a 165°F thermostat will run cooler than an 180°. Chevrolet data, for where the high for normal operating temperature occurs, is generally in the 220-230°F range and that's going to happen no matter what thermostat is installed (as long as it's rated below that range). I think those unaware of the normal range get frightened when they see the temps this high.
Old Jan 22, 2023 | 11:15 AM
HeadsU.P.'s Avatar
HeadsU.P.
And 50 more horse.
Old Jan 22, 2023 | 02:15 PM
Rescue Rogers
while others dont understand that an engine does make more horsepower at cooler temps and that running a 165F merely allows the engine to cool to that temp versus staying at or above 200F with a 195F thermostat. And please dont compare todays temps, emissions standards and horsepower numbers with the relics that come in our 50 year old cars...theory may remain constant but technology does not and has bypassed these dinosaurs
To 1970 - thermostat missing?
