Binding half shaft U Joints
Old Feb 5, 2023 | 10:50 AM
C4toC2's Avatar
C4toC2
Default Binding half shaft U Joints
Had the 71 big block up on jack stands and went to turn on of the wheels. Sure enough, the inside U Joints do bind. So I'm wondering if this is factory or if the KYB shocks that were installed are too long allowing too much downward travel.
Old Feb 5, 2023 | 11:01 AM
Hammerhead Fred's Avatar
Hammerhead Fred
If you've got it up on jack stands with the trailing arms hanging down w/o any support they will indeed bind.
You need to raise the trailing arms up to something approaching ride height in order to turn the rear wheels.
Old Feb 5, 2023 | 12:40 PM
kansas123's Avatar
kansas123
Raise the rear via the differential, then carefully raise both trailing arms a little at a time to keep from toppling the car over
Old Feb 5, 2023 | 06:10 PM
derekderek's Avatar
derekderek
So if you go over a high spot in the road and the car lifts off the suspension, are you damaging the u-joints?
Old Feb 5, 2023 | 10:06 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
The Chevy power book recommends the following for racing prep, make sure the shocks prevent the u-joints from going into bind during suspension droop, or use limiter straps.
Old Feb 5, 2023 | 10:12 PM
interpon's Avatar
interpon
Exactly what i was thinking. I always turn wheels (manually ) when off ground no issues.
the bilsteins hd shocks i put on limited the drop even more than original shocks.
now no shocks on would be an issue I suspect at full droop?
Old Feb 6, 2023 | 11:34 AM
interpon's Avatar
interpon
found the pic.. AC Delco MX repop vs HD Mx Bilstein.. did not measure the originals..be curious to see what they are OEM?
FYI the ac delcos are JUNK
Old Feb 8, 2023 | 10:29 PM
C4toC2's Avatar
C4toC2
Great information - thanks for all the contribution. At this point I'm thinking my shocks are too long fully extended. At some point I'll switch them out for QA1s or Bilsteins and until then try to keep the beast on the ground.
To Binding half shaft U Joints
