Big block oil pan
Old Feb 7, 2023 | 02:00 PM
Sayfoo's Avatar
Sayfoo
Default Big block oil pan
I'm going to replace my '69 bb oil pan gasket, and possibly my rear main seal, and I'm wondering if I should run the car up a set of ramps, or jack it up and let the wheels hang loose. I'm thinking that I should get more clearance if I let the suspension hang down. I remember 15 yrs ago when I replaced the gasket, that reinstalling the pan was a bit of a pia because it doesn't just go streight up, because of the oil pick up tube.
What do you think?
Old Feb 7, 2023 | 02:18 PM
Jeffs82c3's Avatar
Jeffs82c3
I use a floor jack and raise the car high enough to slide the ramp under, but I turn the ramp around so I can slide under easily, then do the opposite side the same way. I don’t like having the front end hanging.
Old Feb 7, 2023 | 03:11 PM
John 65's Avatar
John 65
I changed mine on ramps 2 years ago. The back of the ramps were removable for more room. Plus of course jack stands too.
Old Feb 7, 2023 | 05:29 PM
69L88's Avatar
69L88
I don’t see any benefit from a fully extended suspension for the work you are contemplating.
As others have stated, don’t let the front “hang”. Be sure you put support under the area of the frame horns if you are jacking on the frame.
Old Feb 7, 2023 | 06:07 PM
HeadsU.P.'s Avatar
HeadsU.P.
RAMPS !!! So much safer.
I wonder if the pump screen was truly what was hanging up on your last oil pan swap. Sometimes the front crank counterweight is hanging down. If at any time the front of the pan is fighting you, just jog the key to get the weight up in the block. There was an old trick of putting a certain cylinder on TDC to assure the counterweight was clear of the pan before unbolting. Anyone? Anyone?
If I could give one piece of advice on pan removal. Buy a 1/4" drive extension about 10" long. Slips right in there to get those pan bolts off. Not everybody has 1/4" drive ratchet / sockets but they should have for a task like this.
Old Feb 7, 2023 | 09:38 PM
Sayfoo's Avatar
Sayfoo
I'm thinking that I have to drop the drag link/tie rods, idler arm, etc. and it may go lower if the suspension is hanging????
Old Feb 7, 2023 | 09:56 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
By just removing the two idler arm bolts from the frame the steering linkage will drop low enough to get the stock pan off. Did this with my 427 a year ago and it provided plenty of clearance. This is a standard steering car, not power, so that may make a difference but it's quick to disconnect and see.
Old Feb 8, 2023 | 01:07 PM
Peterbuilt's Avatar
Peterbuilt
Default Good advise
On a small block:
After you drop the idler arm, turn the timing mark to the 5 o'clock position (as viewed from the front) to get the weight out of the way. Might work on a big block too.
Good advise.
Old Feb 8, 2023 | 02:12 PM
Sayfoo's Avatar
Sayfoo
I hadn't thought about the crank weights, but it makes sense that they could be a problem.
Thanks everyone.
Old Feb 8, 2023 | 09:14 PM
derekderek's Avatar
derekderek
cheap harbor freight wobble extensions also work good here. sorta like a partial u-joint.
To Big block oil pan
