Need some help w/sequencing module
Old Feb 8, 2023 | 01:00 PM
VetteZr's Avatar
VetteZr
Default Need some help w/sequencing module
Need some input from any of you electrical wizards, I am rewiring a 74 coupe, when I started the taillamp harness I came across what I learned is a "sequencing module" one question I have is where can I buy one as this one seems to be too corroded to function and two, what exactly does it do, I believe it is connected to the seat belt wiring, but does it do anything else? And finally three, if I cannot find a replacement, will the car function in the absence of this sequencing module? See photos below, thanks in advance for any help or suggestions.
Don
Old Feb 8, 2023 | 01:24 PM
Peterbuilt's Avatar
Peterbuilt
Look on the passenger side firewall and locate the relay mounted on an orange base.
Remove the relay and jumper from X to X.
Old Feb 8, 2023 | 01:34 PM
VetteZr's Avatar
VetteZr
Thanks Pete, (talk about a bunch of useless technology, thanks GM)
To Need some help w/sequencing module
