Brake line adapter.
Old Feb 11, 2023 | 11:57 AM
540 vette's Avatar
540 vette
Default Brake line adapter.
I need an adapter to connect a -3 male fitting to a 5/16 male brake hardline.
Old Feb 11, 2023 | 01:07 PM
kossuth's Avatar
kossuth
5/16????? Are you sure you didn’t mismeasure? Most lines are 3/16 or 1/4.
Old Feb 11, 2023 | 01:35 PM
540 vette's Avatar
540 vette
3/16
Old Feb 11, 2023 | 05:36 PM
kossuth's Avatar
kossuth
3/16
As long as your tube nut is 3/8-24 here are your options.
https://www.speedwaymotors.com/Speed...ing,32433.html
https://www.summitracing.com/parts/rus-641291
Old Feb 11, 2023 | 07:23 PM
540 vette's Avatar
540 vette
The -3 end has to be female.
Old Feb 11, 2023 | 08:29 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
is the fitting size 3/16 or the line...you may need something like this with and inverted flare....https://www.summitracing.com/parts/ear-562046erl
Old Feb 11, 2023 | 08:54 PM
kossuth's Avatar
kossuth
Nothing I know of that does that without a coupler. You want to use steel if you have to use a coupler. I don’t know where else to look.
https://speedflowusa.com/3-steel-female-union/
Old Feb 12, 2023 | 06:59 AM
540 vette's Avatar
540 vette
Did some research and will use a tube nut and a tube sleeve. I will flare the line to 37 degrees and thats how you do it.
Old Feb 13, 2023 | 09:59 AM
kossuth's Avatar
kossuth
Make sure you use steel. These are brakes obviously.
Old Feb 14, 2023 | 08:34 AM
540 vette's Avatar
540 vette
Everything steel
To Brake line adapter.
