1980 Starter Electrical Issue
Old Feb 13, 2023 | 11:05 AM
Tauanger68's Avatar
Tauanger68
3rd Gear
Default 1980 Starter Electrical Issue
Purchased a portable jump starter for my 1980. Used it once and it appears it shorted out something. Ordered a new fusible link assembly for a 1980 but it’s different from the existing one and appears the late model years are using one from a 81. I have 12 volts coming out of my battery. Replaced starter, solenoid, ignition switch. Old fusible link appears fine after testing it. Any advice is greatly appreciated.
Old Feb 13, 2023 | 04:44 PM
MelWff's Avatar
MelWff
Do you have 12+ volts at the large solenoid terminal?
Do you have 12+ volts at the S terminal on the solenoid when you turn the key to start?
