My 75 vette power brakes go down to the floor with little stoppage.
Bled all 4 brakes and fluid level good, no leaks. Brake pads also good.
Could it be master cylinder and/ or booster?
Once this is done I usually do a pressure bleed of each caliper bleeder.
So you dont waste brake fluid capture the bleeder fluid into a jar and recyle into the MC.
I pressure bleed using the adapter / clamp on the MC.
You have to continue to troubleshoot
You said that no leaks at the calipers but were both sides of the master cylinder full?
The M/C can leak into the booster.
To test the M/C:
Plug one line with the other connected and see if the pedal is rock hard then reverse the plug and the line and test again.
The pedal should be rock hard in both tests, if not the M/C is bad.
Caution if you plug the MC for testing. Do Not Use a Bolt. There is a flare inside those ports on the side of the MC. A bolt can destroy the casing.
You can make two test lines out of short lengths of steel pre-made lines at NAPA, about a foot long. You will need the port hole diameter and TPI from both ports which are different, but both are common sizes. Then plug the end of the test line or simply pinch it off. There may be 400 lbs of pressure on the line from the brake pedal.
Keep in mind that after testing the MC you have introduced air into the entire system.
No, I recently bought it and has always been this way. Pedal goes to the floor, car does stop but not like it should. Also, pulls to the right at stop.
