Spindle condition
Old Mar 9, 2023 | 02:49 PM
piste's Avatar
piste
Banned Scam/Spammer
Default Spindle condition
Got my passenger side knuckle assembly off. New territory for me. Just curious to get a quick assessment as to whether anything looks bad with this spindle...meaning too worn??
Thanks.
Old Mar 9, 2023 | 03:36 PM
Avispa's Avatar
Avispa
I don't see anything worn on that spindle, including the surface for the inner bearing grease seal. Clean er up and put er back together. It looks like you need to replace the grease seal if you haven't already.
Old Mar 9, 2023 | 04:03 PM
piste's Avatar
piste
Banned Scam/Spammer
Thanks. Just curious your comment about the seal...and I am still learning here...do you say that because of the amount of the grease that is shown on the spindle. Currently the seal is in the hub I took off.
I do intend to replace everything I should..but first wanted to make sure I was building back better on a good spindle!
Old Mar 9, 2023 | 04:47 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi Again
The old seal leaked so yes, replace it.
Chean up the spindle and maybe Gary R. will reply.
Old Mar 9, 2023 | 04:50 PM
piste's Avatar
piste
Banned Scam/Spammer
Thanks...am going to...and no need to take up Gary's time as these are already destined for his shop for the final work!!
Old Mar 9, 2023 | 05:54 PM
Avispa's Avatar
Avispa
Yes, definitely mentioned the seal bc of all the grease on the spindle. It could be other stuff, like brake fluid leaking from the caliper, but go with grease for now. The seal is exactly where it's supposed to be. To replace it, you tap it into the seal bore on the hub, preferably with a correct size driver tool, but you can use PVC pipe.
Old Mar 9, 2023 | 06:05 PM
piste's Avatar
piste
Banned Scam/Spammer
Again I thank you!! I was very happy to get this assembly off today. Could not get the lower ball joint out despite copious PB and pounding with a pickle fork. Have a local shop who can probbably help me with that. Hopefully have better luck with the other side.
Old Mar 9, 2023 | 07:38 PM
Avispa's Avatar
Avispa
Out of sheer frustration at a lower ball joint from time to time, I just unbolt it from the lower control arm and take the spindle to a machine shop and get the joint pressed out
To Spindle condition
