Interior dye aerosol on steering column
Old Mar 14, 2023 | 07:36 PM
Bill218's Avatar
Bill218
Default Interior dye aerosol on steering column
I bought interior spray paint from a corvette supplier and it says for hard plastic, leather and vinyl but really doesn’t say anything about pot metal like on the C3 column. It’s called 68-82 interior dye aerosol. Anybody have experience using this? Thanks, Bill
Old Mar 14, 2023 | 07:54 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I am using a similar product now for a column piece.
paint is thin. won't self level so surface must be smooth
takes many coats
takes time to harden.
I am covering in clear laquer
Old Mar 14, 2023 | 07:57 PM
Bill218's Avatar
Bill218
Originally Posted by calwldlife;[url=tel:1606387361
1606387361[/url]]I am using a similar product now for a column piece.
takes many coats
ok.. sounds good! I guess that’s the only option. I figured it might be a little weird on metal. Thanks
Old Mar 15, 2023 | 11:41 AM
Lamouree351's Avatar
Lamouree351
I used it on my column a couple years ago and it has worked fine
Old Mar 15, 2023 | 11:44 AM
walleyfisher's Avatar
walleyfisher
Mines been on since '86 no problem, just make sure to prep with acetone before spraying (eliminates chance of fish eyes)
Old Mar 15, 2023 | 02:43 PM
tkucala's Avatar
tkucala
I used it on my steering column for my 1969 and it came out nice.
Old Mar 15, 2023 | 09:57 PM
Fly skids up!'s Avatar
Fly skids up!
Why is it called dye when in reality it's just paint? Dye is for Easter eggs and vain Corvette owners.
Old Mar 16, 2023 | 08:03 AM
walleyfisher
Because it is really "runny" and works on fabric too
Old Mar 16, 2023 | 09:58 AM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
So they can charge more for it.
Old Mar 16, 2023 | 10:08 AM
Fly skids up!
Ha Ha, I do a pretty good job of running Behr ultra.
Old Mar 20, 2023 | 04:32 PM
7T1vette's Avatar
7T1vette
You can use interior dye on metal. It may not stick at firmly as regular paint, but if it is not in a high-wear area, it shouldn't be a problem. I use it on my column...because I wanted all the interior to match.
Old Mar 21, 2023 | 06:22 PM
68/70Vette's Avatar
68/70Vette
Yes. For metal you need paint. For plastic, paint also works well. For the vinyl trim pieces, not just the seats, but the vinyl covered dashes, door panels, etc. you need dye. To change the color of a trim piece, it's tedious. The dye is a very thin coat. It takes multiple coats to get the desired satisfactory effect. And you need to wait between the multiple coats, so it's time consuming. Try to speed the process up, or attempt to lay down a thick coat, will just make a mess.
Old Mar 21, 2023 | 07:40 PM
Fly skids up!
Yea, you can spray that so called dye ten different ways to Sunday on to Vinyl and it will still scratch off. It doesn't penetrate or permanently change anything. It just top coating.
Old Mar 22, 2023 | 12:15 AM
tonyd21266's Avatar
tonyd21266
Yes. The only difference in the dye/ interior sprays are a flex additive. Basically, it's like using the paint that is mixed for a urethane bumper.
Old Mar 27, 2023 | 11:34 PM
7T1vette's Avatar
7T1vette
"REAL" vinyl dye will not scratch off. It bonds to the plastic. If it scratches off, it has been applied to un-clean (or pre-coated) vinyl/plastic or it isn't really vinyl dye. Most stuff in the market labeled as "dye" is just paint with a flex additive included. Paint WILL scratch off.
Old Mar 28, 2023 | 07:30 AM
Fly skids up!
Can you provide a list of real vinyl dyes?
To Interior dye aerosol on steering column
