1982 Net Getting Fuel
Old Mar 18, 2023 | 02:24 PM
rfscholl's Avatar
rfscholl
7th Gear
Default 1982 Not Getting Fuel
Hello! I have an 82 that will not fire because there is no fuel getting to the TBs. I pulled the fuel pump and it works when I connect it straight to a battery. When I meter the wires coming from the car going to the pump I am only getting 8.5 volts. When I meter the fuel pump fuse with the key on, I get 0 on both sides of the fuse. I'm pretty sure that is where my problem is but I'm not sure where to go next. I have not dug into the fuel pump relay yet but I believe the power should start at the fuse block, so I think I need to sort that out first.
Any suggestions? Thanks!
Old Mar 18, 2023 | 03:16 PM
MelWff's Avatar
MelWff
If you look at a circuit diagram the fuse is AFTER the relay and oil pressure switch.
Old Mar 18, 2023 | 07:21 PM
rfscholl's Avatar
rfscholl
7th Gear
Thanks! I did find a diagram online and I see what you mean. Since the oil pressure cutoff in not in play until after the engine is running, it's got to be the relay. I'll start there.
Old Apr 6, 2023 | 07:26 PM
Kmatthewe's Avatar
Kmatthewe
1st Gear
I am have the same exact issue! Replaced relay, still nothing…. 8V at the pump with key on Zero at the fuse panel on both sides of the fuse.. although white/tan at the pump has zero also…
please let me know if you figure it out 😓
Old Apr 6, 2023 | 08:47 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Check the 20amp fuse in the battery box. If that is bad, the engine will crank, will have spark, but no fuel. Hope that is your issue.
To 1982 Net Getting Fuel
