Blue smoke
Old Mar 20, 2023 | 05:21 PM
7T3stinger's Avatar
7T3stinger
Originally Posted by AKjeff
Could be though I'd be surprised if it did it before and after the heads were off for new guides and seals.
Another thread here mentions heads with screw in studs that go into the intake runners. You may have one of those leaking.
It's a simple matter of pulling the screw in stud and putting some sealant on the threads, if your heads are constructed like that.
If you find one plug with oil on it it would indicate which stud it is.
Does the car smoke while decelerating?
Have you contacted the engine builder about this? I'd be curious what they'd have to say.
I have some plug pics up if you care to look at them.
Old Mar 20, 2023 | 06:13 PM
AKjeff's Avatar
AKjeff
I don't think the plugs look bad, there is a bit of soot at the top of the threads.
If it were my engine I think I'd be looking at the intake manifold gasket.
Before pulling it apart you could inspect the intake runners with a borescope, they make them now that will link to a smart phone.
How much oil is it going through?
Old Mar 20, 2023 | 06:19 PM
7T3stinger's Avatar
7T3stinger
not much oil. I’m not a mechanic so i do t even know where to begin with doing that. Lol.
Old Mar 20, 2023 | 09:10 PM
Stormin_Normin's Avatar
Stormin_Normin
Borescope is cheap and will tell you a lot. That’s the place to start.
Old Mar 20, 2023 | 09:29 PM
7T3stinger's Avatar
7T3stinger
I’m not a mechanic and would t know what to do or where to start.
Old Mar 21, 2023 | 01:16 PM
wwiiavfan's Avatar
wwiiavfan
A borescope is just a mini camera that fits into tight spots like thru the spark plug hole or thru the top of the intake and into the intake runners. You’ll be able to see if there is wet oil clinging to surfaces where it shouldn’t be.
Old Mar 21, 2023 | 03:26 PM
7T3stinger's Avatar
7T3stinger
Yes I have researched this. But I wouldn't know what I'm looking at. Where through the top of the intake? Take the carb off? I will probably end up taking back to who built the engine. I posted plug pics hoping someone else had the same problem and could tell me if it may be a cracked intake gasket or maybe head gasket. Thanks.
