Leak Down Test Results
Old Mar 21, 2023 | 06:56 PM
rtdice94's Avatar
rtdice94
5th Gear
Default Leak Down Test Results
I just picked up a 78 from my grandfather. He said his cousins drove the car for a year until they gave it back. I bet I know why they gave it back. We just did a leak down test today because it is backfiring through the carburetor. We were trying to rule out valves before we went the wiped cam route. Our findings had 78% on one, 40% on another and 36% on another blowing air out the fill hole in the valve cover and the dipstick tube. Are there any other alternatives it could be other than bad rings? Just wanted to make sure we aren't overlooking something before we get into a rebuild stage. Thanks for any insight! Also if anyone has any insight on the backfiring I will take that too. There were no leaks through the intake or the exhaust. It runs smooth as silk idling and starts to backfire once revved up to higher RPMs.
Old Mar 22, 2023 | 03:32 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Those are really bad leak down test results.
sounds like more than just rings. Most likely rust damage to the bores.
With results like that I would just start taking it apart.
Old Mar 22, 2023 | 03:45 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Rookie question...could the timing chain have jumped a tooth (or more) on the gear?
I had a 383 engine that jumped timing so much that it idled well but had no power.
It took the mechanic an hour of troubleshooting to solve the problem/plastic timing gear teeth crumbled.
The good news was...no bent valves.
1 in 100,000,000, but it happened
Old Mar 22, 2023 | 03:57 AM
4-vettes's Avatar
4-vettes
Jumped cam timing wouldn't cause leak down.
So no. Absolutely not the issue
Old Mar 22, 2023 | 08:43 AM
HeadsU.P.'s Avatar
HeadsU.P.
rtdice94,
Before tearing into this engine, you could do a quick test.
With the valve covers off, have a helper sit behind the wheel. You will be checking for any valve that is not closing completely. Look at the first cylinders rockers. When both valves are closed, there should be a slight movement of the rocker. Have your helper jog the IGN key and move right down the line grabbing rockers.
Valve lash set too tight will allow air to blow out the valve cover ports.
Valve lash set too tight will give horrible Leak-Down results.
Old Mar 22, 2023 | 10:10 AM
Stormin_Normin's Avatar
Stormin_Normin
It could be valves or rings/pistons, if the valve lash is good you're going to be tearing it down. You can do a wet compression test to confirm rings or valves.
Old Mar 22, 2023 | 03:43 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Well leak-down should be 90%+.
So you are leaking a lot of air...somewhere.
While you have the leakdown gear hooked up, you should listen to both the exhaust pipe, the valve cover oil fill hole, and the carb.
All that air-leak has to be going out one of those places.
Then you will have more clues as to where the problem lies. You may even rule-out one or two.
Old Mar 22, 2023 | 04:00 PM
gkull's Avatar
gkull
Guys listen to what he said. NO leak down air in the intake or exhaust
So it's not a valve or cam problem.
Poster said excessive blow by
Old Mar 22, 2023 | 09:23 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Yep no intake valve or exhaust valve sealing problem.
So it has to be leaking past the rings.
Next step I would do is stick a borescope down a sparkplug hole and see how the cylinder walls look.
It could be rust, or sticking rings. For the low leak down readings.
The popping could be a lot of things.....
Old Mar 23, 2023 | 09:16 AM
gkull's Avatar
gkull
I might even question such bad leak down numbers because I wasn't there during the test. It take a higher HP air compressor to supply a constant 100 psi. It's not going to happen with a Harbor Freight 3.5 HP with a 20 gallon tank.
You have to be right at TDC because it will rotate the motor.
The only time in my life that I ever saw horrifically bad leak down numbers like that was when I installed Keith Black Hypereutectic in my L-82 355 ci. They smeared aluminum down through the rings locking them in the lands. The motor sounded like it had terrible rod knock from piston slap. No ring sealing at all. Cracked or detonation burnt through pistons from NO2, But those kind of motors smoke horribly out the exhaust because they are just burning oil.
Old Mar 23, 2023 | 09:28 PM
rtdice94's Avatar
rtdice94
5th Gear
Originally Posted by HeadsU.P.
rtdice94,
We went through doing this checking for rocker arm movement. They all had the same travel which we weren't expecting since we assumed a wiped cam. We didn't wiggle each arm to check the lash, I will have to to that and report back. Thank you for the recommendation!
Old Mar 23, 2023 | 09:41 PM
rtdice94's Avatar
rtdice94
5th Gear
It's an 80gal compressor using a Snap-On tester. We found TDC with a screwdriver in the spark plug hole until the piston stopped moving up and tested at that. We have in the past had a motor start to turn but had all the plugs out of that one. This one we did one plug at a time so it didn't' try to rotate on us. The car doesn't smoke at all and runs very smooth at idle. It pulls strong through the power band even once it gets up to higher RPMs but that is when it starts to backfire. No loss of power, smoking, hesitating, knocking etc. That is why we are trying to cover out bases because if it leaks past the rings this bad we would have thought it would smoke real bad. Anything you can think of that we are overlooking/not doing properly?
Old Mar 23, 2023 | 10:35 PM
4-vettes's Avatar
4-vettes
I'd say, back up a bit. Basics.
What do all 8 plugs look like?
Have you run a compression test?
High speed miss could very well be a ignition system component. Like a failing coil or ign. module.
Old Mar 24, 2023 | 09:46 AM
HeadsU.P.'s Avatar
HeadsU.P.
Keep in mind a "wiped" cam lobe has no reflection on a Leak-Down-Test. A Leak-Down-Test is for checking piston rings, valve, and head gasket. sealing capacity that is stationary. The Leak-Down test doesn't even care if there is a camshaft installed. Its measuring loss of air pressure from top of piston to the closed valves.
A wiped cam lobe does however, affect the compression testing because the valvetrain is now put into action for this test.
There are some products on the market that claim to repair cylinder wall scratches. Supposedly, it fills in the voids in the walls caused by ring end gap damage.
I assume these products are introduced through all eight sparkplug holes. Then spin it over.
Off hand, I can't remember the name of the product. Maybe someone else has some thoughts on if it works or not.
And you really need to check that all 16 valves are truly closing all the way. Wiggle those rockers.
Old Mar 24, 2023 | 09:56 AM
rtdice94's Avatar
rtdice94
5th Gear
Most looked good. 2 or 3 had pretty weak spark. The number 3 cylinder with the 78% leak spark plug had a questionable oil smell to it and weak spark. The compression test was next but we are headed out of town and my buddies are headed to the racetrack so we didn't get to it. Recommend both wet and dry? Or just a dry would tell you enough. We didn't anticipate the leak down results that we got because as we ran it and drove it like I said before it didn't smoke, knock, ping, or hesitate so how the motor performs doesn't quite line up with the leak down results so I wanted to see what we could be overlooking before having to go through a rebuild. We were only trying the leak down test to see if a valve was bad or if the camshaft was bad and ended up with those results lol.
Old Mar 24, 2023 | 02:08 PM
gkull's Avatar
gkull
Pot metal austempered cams from Comp Cams started out around the year 1998? (but don't quote me on that) Big companies like comp make cam cores and the smaller vendors grind them to their specs. I had a flat fuel pump lobe on my CC extreme H-roller grind. I was so pissed about the whole deal that I went to billet steel cams. I would rather pay a little more now than a wheel barrel full later with a trashed motor from metal in the oil.
That is when the proliferation of lobe ware in a short period of time started. If you have an original GM cam from pre 2000 you are not going to have flat lobes unless you use some substandard oil with rare oil changes.
Old Mar 24, 2023 | 03:37 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
<snip>
There were no leaks through the intake or the exhaust. <snip>.
If your comment above means NO hissing thru the intake or the exhaust, DURING the leakdown test, then you have NO valve sealing problems. If so, stop worrying about the valve lash. The valves are seated. Your leak must be the ring/bore seal. It needs a borescope or to come apart.
You could however still have a wiped cam, and only getting half of the normal lift, but that is another issue entirely. But with the above problem, it's irrelevant.
Old Mar 24, 2023 | 03:55 PM
Mr D.'s Avatar
Mr D.
I would step away for a fresh beer and go back and address the backfiring through the carburetor that has nothing to do with your leakdown test. I would start with an inspection of the fuel / timing / ignition systems.
To Leak Down Test Results
