Quadrajet Sputter Turning Off
Old Mar 21, 2023 | 07:42 PM
MD383's Avatar
MD383
Cruising
Default Quadrajet Sputter Turning Off
Hello, my 7040203 quadrajet is causing a sputter when turning the engine off sometimes. I have the throttle blades practically closed and the idle at 800. My carb does have idle bypass air so this allows my throttle blades to be closed more and I bumped my initial timing up and used manifold vacuum advance. Is this normal for a quadrajet because my Holley doesn’t have this problem.
Old Mar 21, 2023 | 10:01 PM
MelWff's Avatar
MelWff
it was suggested in your August post to run 32 total not 36. Did you try that?
Old Mar 21, 2023 | 10:10 PM
MD383's Avatar
MD383
Cruising
Yeah I decreased my initial to 18 and have 32 total but it runs fine and I can lower my idle. 800 seems high but if I lower it then the car can stall if I turn my heat on. I have a stock 55 amp alternator but I’m thinking it may not be putting out enough amps at that low of an idle. Stock pulley sizes.
Old Mar 21, 2023 | 10:39 PM
MelWff's Avatar
MelWff
if you lower it do you still have the shutoff problem?
Did you change anything on the carburetor after the rebuild and did you tell them the specs of your engine?
What ignition system and what is it using to provide powet?
Old Mar 21, 2023 | 10:47 PM
MD383's Avatar
MD383
Cruising
MSD 8360 no ignition box. Carb was rebuilt to my combination, nothings changed. I haven’t tried driving the car and seeing if it won’t do it with the lower idle because it’s been so cold and I haven’t driven the car. I’ll test it out tomorrow and post the results.
Old Mar 21, 2023 | 11:06 PM
MelWff's Avatar
MelWff
what year is the car?
Old Mar 21, 2023 | 11:08 PM
MD383's Avatar
MD383
Cruising
1970
Old Mar 21, 2023 | 11:22 PM
MelWff's Avatar
MelWff
1970
So where are you getting the power to the red wire coming from the distributor?
Old Mar 21, 2023 | 11:28 PM
MD383's Avatar
MD383
Cruising
Coil.
Old Mar 21, 2023 | 11:37 PM
MelWff's Avatar
MelWff
Coil.
OK, where is the coil getting power from, the original double wire factory connection? If so, instructions indicate 12 volts required. The factory wires use a resistor wire that does Not provide 12 volts when running. That could account for your problem when turning on heater, voltage drop to ignition system.
Old Mar 21, 2023 | 11:45 PM
MD383's Avatar
MD383
Cruising
Yes, the factory double wire connection. I forgot about the resistors due to the fact that the car originally had points. I can’t wait to rub a new wire to the fuse box tomorrow! Thank you.
Old Mar 22, 2023 | 08:54 AM
MelWff's Avatar
MelWff
there is an empty blade marked IGN
Old Mar 22, 2023 | 07:43 PM
MD383's Avatar
MD383
Cruising
That cured it. Perfect.
To Quadrajet Sputter Turning Off
