Spare tire lock bolt pin
Old Mar 26, 2023 | 01:19 PM
piste's Avatar
piste
Banned Scam/Spammer
Default Spare tire lock bolt pin
What purpose does this serve? You can see attached pics of what I have...seems to be worn to dysfunction. Not talking about the part that threads ONTO the bolt...talking about the pin that goes through the hole near end of bolt. Found can get one at Zip...not sure where else. But why?? Wuzzit do?
Old Mar 26, 2023 | 01:35 PM
AKjeff's Avatar
AKjeff
I think it's there to prevent the bolt from being completely removed from the attaching point while lowering the spare tire carrier.
Any decent hardware store ought to have a roll pin that will do the same thing.
Old Mar 26, 2023 | 01:38 PM
piste's Avatar
piste
Banned Scam/Spammer
That would make sense. Thanks
Old Mar 26, 2023 | 03:53 PM
Mooser's Avatar
Mooser
Completely agree. You could even stuff a cotter pin in there and cut most of the legs off, lots of room around it
M
Old Mar 26, 2023 | 04:27 PM
piste's Avatar
piste
Banned Scam/Spammer
M
Thanks. BTW...what is that white sliver below the bracket nut....between the bracket nut and the bracket??
Old Mar 26, 2023 | 04:38 PM
Mooser's Avatar
Mooser
Nothing really. I added a small piece of neoprene to take up the room when it was fully tightened to stop it from clanking there. I don't run a spare in the tub so it's not fully "tight"
M
Old Mar 27, 2023 | 10:15 PM
piste's Avatar
piste
Banned Scam/Spammer
So my challenge now is to drive out the stub of the original pin that is left in there and is flush with or below the threads and therefore ineffective in it's purpose. Should be do able. And several solutions have been offered for a substitute/replacement once I get the stub out.
Old Mar 28, 2023 | 01:18 AM
gbvette62's Avatar
gbvette62
It's purpose is to serve as a stop, to keep the lock bolt from completely threading out of the lock bolt nut. And as Akjeff said, it's just a standard roll pin that you can get at any hardware store. I would think a roll pin's a better choice then a cotter pin, if for no other reason then it should be a little stronger.
To Spare tire lock bolt pin
