C3 overheating
Old Mar 29, 2023 | 07:20 PM
clayzigler's Avatar
clayzigler
Default C3 overheating
Hope some of you have some thoughts on this. I have a 1978 that has been having overheating issues. I had to have a new engine installed as well as a new radiator. I have taken the car back to the shop and they cannot pinpoint the overheating. They replaced the thermostat and clutch fan but it still overheats. Driving in the city not a real problem but once on the highway after 20 to 30 minutes the gauge get hot.
Old Mar 29, 2023 | 07:28 PM
Corey_68's Avatar
Corey_68
Are you running an air dam and radiator seals?
Old Mar 29, 2023 | 07:39 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
how fast and what rpm?
Old Mar 29, 2023 | 07:54 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
do you have the spring inside the lower radiator hose....there are a ton of posts on the subject and it can be anything form timing to bad circulation and a just plain gummed up radiator and cooling system. When was the last time you drained the block from the bottom and flushed all the rust and crud out and back flushed the radiator?
Old Mar 29, 2023 | 07:58 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
spring is a good suggestion
Old Mar 29, 2023 | 08:35 PM
clayzigler's Avatar
clayzigler
Brand new engine and radiator along with hoses.
Old Mar 29, 2023 | 08:36 PM
clayzigler's Avatar
clayzigler
Around 70 mph, not sure on the rpm.
Old Mar 29, 2023 | 08:40 PM
interpon's Avatar
interpon
Post pics of front spoiler, seals around radiator.
assume timing ok.
Old Mar 29, 2023 | 08:56 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Good air flow, good water flow, crucial
interpon pics
rescue rogers, spring
good luck
Old Mar 29, 2023 | 09:04 PM
rmrtrex's Avatar
rmrtrex
Things to look into:
Radiator clean/flush, water pump not working, Thermostat not opening, spring in lower hose, fan clutch not engaging, timing, fan shroud not having the proper seals around it.
Before you start car in the morning take radiator cap off, then turn car on and let it run for about 10 minutes. Look into radiator and make sure water is actually circulating.
Old Mar 29, 2023 | 09:29 PM
AKjeff's Avatar
AKjeff
Has the accuracy of the gauge been verified?
Old Mar 30, 2023 | 05:09 AM
Rescue Rogers
If everything is nee then its almost definitely a mismatched sender to gauge or there is no spring. I have yet to buy a new lower hose that has one included
Old Mar 30, 2023 | 05:10 AM
Mr D.'s Avatar
Mr D.
Corvette Cooling System Basics
File Type: pdf
Old Mar 30, 2023 | 05:18 AM
Mr D.'s Avatar
Mr D.
Usually overheating issues are in city related and vice highway, what temps are you seeing in city vice highway? Does the car puke coolant when this happens?
Water boiling point is 212F, at 15 psi that boiling point is increased to 249.8F. A 50/50 mix of water and antifreeze will add 11F buffer to those number so in reality the car pukes out the overflow when the water temp is 260F or higher.
Old Mar 30, 2023 | 06:13 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
And new hoses usually DONT have the spring in the lower hose.
ign. Timing???
How much vacuum advance timing are you running.
Does your vac.can have all the timing in 2 inches below your idle vacuum number?
Old Mar 30, 2023 | 07:14 AM
HeadsU.P.'s Avatar
HeadsU.P.
Which Water-Pump? Some are reverse rotation for a serpentine belt system.
Old Mar 31, 2023 | 07:55 AM
Bikespace's Avatar
Bikespace
Squeezing the lower rad hose should take the OP 3 seconds, and will confirm the absence of the spring. If it is anything else, I'll be surprised. But pick up an IR temp gun to check, too.
To C3 overheating
