Im planning on changing the carb on my 81, my coworker says that I shouldn’t need a new dis but I have read that it will run really terribly if I don’t.
So I was wondering how he’d is it to change the distributor?
I know it’s not as simple as just stabbing it in. How do I hook up the vacuum advance since the original doesn’t have one? Also will the connections just plug in ?
Also is there another besides carb and dis to switch to switch to mechanical? I have a four speed so I know I don’t need to do anything with a TCC
OK. Sounds like you haven't done any homework at all.
yes it really is as easy as stabbing it in. Set up the timing. Connect vac advance can to manifold vacuum.
Install a carburetor from a earlier model or a basic Holley.
getting ALL the vacuum lines hooked up again will be different from stock. But not impossible.
Me, I would lose the stock intake manifold and install a Holley. A fair few ways to do this.
perhaps do some reading.
Just set everything up like a 1980.....
Do not buy a square bore carb to put on the manifold with an adapter.......very bad idea.
DO NOT buy a Q-Jet from a rebuilder......they are pretty terrible now.....
Find a good unmolested core from another Vette and have Lars go through it......
Lars has papers on how to install your distributor too......
The stock Rochester Quadrajet is an outstanding carb if it is set up properly. It's hard to beat, as well chronicled on this forum, and elsewhere, by those who would know. The stock intake manifold is also excellent. It's not easy to improve on the factory fuel delivery systems installed on C3 cars. Also, consider that all '81 cars had aluminum intakes, as did an increasing number of late C3 cars, after '77.
Jebby
when changing the carb is there any special thing I need to do with the electric choke? Should it just switch over and if I can’t keep it how do I set up a manual choke
Your car is already wired for electric choke. It gives you a lot more intake options. I'd switch it over if you can. Otherwise, you need an intake with provisions for a heat stove connection. Cliff Ruggles sells an electric conversion kit, along with the "correct" Q-Jet rebuild kit that will resist ethanol.
