AC Condenser
I have a 1980 Corvette with electric fans that runs at 180-185 degrees even in the hottest weather in Miami. Issue I have is that the temp jumps up to 220 degress if it's not too hot outside and will continue to climb if it over 90 degrees ambient. I'm assuming the condensors temp is significantly taxing the cooling system and wonder if there are more efficient condensors on the market that could help with this issue.
TIA
