Leafspring bushing help
Old May 3, 2023 | 03:22 PM
Kid Again's Avatar
Kid Again
Default Leafspring bushing help
Ok, so I watched a couple YouTube videos and I guess I wasn't paying attention well enough because I only did half the job (lower bushings are replaced). Is there a hole on top of this bracket to get the bolt out? I wasn't real comfortable sticking my head between the wheel well and brake caliper, and when I felt around I didn't feel a hole. Any help is much appreciate. I'm mechanically inclined, but working on cars intimidates me.
Old May 3, 2023 | 03:44 PM
69L88's Avatar
69L88
Yes, there is a hole. You need to remove the two bolts holding the sway bar link and you will see it.
Old May 3, 2023 | 04:07 PM
Kid Again's Avatar
Kid Again
69L88 Thank you. That explains why I couldn't find it
Old May 3, 2023 | 04:37 PM
interpon's Avatar
interpon
clamp a vice grip or clamp to stop that jack from slipping when you relieve pressure.. be careful. and replace those rear sway bushing too
Old May 3, 2023 | 07:09 PM
HeadsU.P.'s Avatar
HeadsU.P.
^^^this^^^^^^
Sometimes those leafs are extremely greasy from leaky rear axles. One slip of the jack and you are "F"ed.
A block of 2 x 4 held by the strongest "C" clamp you can find will not allow the floor jack to slip.
Don't install the cotter pin in the bolt until you are satisfied with the ride height adjustment. A drop of LocTite Blue on the castle nut doesn't hurt either.
Old May 3, 2023 | 08:22 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
nice orig swaybar
Old May 3, 2023 | 10:32 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
When I replaced my '72 big block's spring bushings I had a heck of a time getting the sway bar rectangular nuts back into the space above the bushing bolt head. With new rubber that space is very full – you're going to have to pry downward with a screwdriver or the like against the bolt head and work the block back in. Maybe someone else has an easier installation trick for this.
Old May 3, 2023 | 11:09 PM
kansas123's Avatar
kansas123
That's how I had to do it too, with a screwdriver and select words....
Old May 4, 2023 | 07:55 AM
Kid Again's Avatar
Kid Again
Thanks interpon, I noticed that after the fact.
Old May 4, 2023 | 07:59 AM
Kid Again's Avatar
Kid Again
Thanks, calwldlife. Other than the radio and possibly the chrome air filter housing and the exhaust the car seems to be all original.
Old May 4, 2023 | 08:03 AM
Kid Again's Avatar
Kid Again
Thanks, 67:72. I figured as much. With just one bushing replaced I had to persuade my wrench into the bracket area to catch the bolt. Gotta love how the YouTube videos all leave this stuff out and make it seem like a 15 minute job.
Old May 4, 2023 | 08:34 AM
Tampa Jerry's Avatar
Tampa Jerry
This past week, Road Kill garage did a piece about removing the rear spring etc. on a 66. This is one of the best demonstrations of how not to remove or service a spring on a C-2 & C-3 corvette. This forum has many posts on how to do the job correctly. Good luck. Jerry
Old May 4, 2023 | 08:37 AM
Kid Again's Avatar
Kid Again
Thanks Jerry.
Old May 4, 2023 | 10:46 AM
Hopper12's Avatar
Hopper12
While you're at it, you might consider replacing the bushings on the link and sway bar as I can see they look very weathered. And then you'll catch the 'while I'm in there' disease!!
Old May 4, 2023 | 12:07 PM
Kid Again's Avatar
Kid Again
Way ahead of you Hopper12 LOL!
Old May 4, 2023 | 03:43 PM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
Man did they blow it on that one. They got very lucky it could have been really bad
Old May 4, 2023 | 08:15 PM
interpon's Avatar
interpon
and fluid comes out of rear bolts????
i was cringing on them hacking the spring lol..
Old May 4, 2023 | 08:23 PM
reno stallion
I asked the question on the c2 forum what's with the gear oil coming out of the housing those bolts don't go though the inside of the housing
To Leafspring bushing help
