Engine wiring harness possibilities
Old May 8, 2023 | 10:16 PM
scottcleaver's Avatar
scottcleaver
1st Gear
Default Engine wiring harness possibilities
Helping a friend that just purchased a 69 427 4-speed car. Engine harness is original and a mess and needs to be replaced. Looking for a little direction please.
1. Best brand for quality and support
2. Is the BBC car any different in the engine harness ( the online harnesses to not show a different part for either SBC or BBC or manual trans vs auto) ?
3. He is going to add aftermarket A/C, would that be any consideration when looking at different brands of harness?
Thanks Scott
Old May 8, 2023 | 10:48 PM
bmotojoe's Avatar
bmotojoe
Lectric Limited is the best for original fit and finish....
These should fit all 1969's.
Engine Harness LINK: https://www.lectriclimited.com/engine-harness-182690
Forward Lamp Harness LINK:https://www.lectriclimited.com/forwa...harness-102427
A/C harness if equipped LINK:https://www.lectriclimited.com/air-c...harness-120453
Idle Stop Solenoid Harness A/C equipped Big Block only LINK:https://www.lectriclimited.com/carbu...-harness-94080
Old May 9, 2023 | 09:54 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I have used the Lectriclimited harness on Big and Small block.......high quality stuff.
My only gripe is they went up about $100 in the last year....
Jebby
Old May 9, 2023 | 12:11 PM
OldCarBum's Avatar
OldCarBum
Also look at American Auto Wire.
I purchased my complete restomod harness from them.
AAW has two type’s available, one is factory original and the other is the restomod harness.
The AAW restomod harness was already set up for a hi amperage alternator, new blade style fuse box and extra length wiring so you can run it different from oem to clean up the engine compartment.
Both companies offer the correct crimping tools to get the job done.
When I checked with both Letriclimited and AAW the ac and power window harnesses were separate harnesses and both told me that since I was going with a Vintage Air ac system, that the VA harness would cover any needs for my ac wiring.
To Engine wiring harness possibilities
