rotor clearance
Old May 21, 2023 | 01:19 PM
Bkerns308's Avatar
Bkerns308
Cruising
Default rotor clearance
I am rebuilding a 69. All new/rebuilt front suspension components. The rotor is not centered in the caliper so the brake pads won't fit on the inside. The RF the rotor is actually against the caliper. I need probably 1/16" to 1/32" to gain the space I need. I'm looking at runout shims but they are only .003-.006, a long way from .0625-.03125. Suggestions welcome.
Old May 21, 2023 | 02:34 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
take a breath and compare to LF
if new bearings and races, verify inner race is seated.
pics because words fail
Old May 21, 2023 | 02:54 PM
69L88's Avatar
69L88
Sounds like you have a rear rotor in a front position. They are NOT the same.
Are you measuring rotor runout? If you don’t get the runout to under ~0.002” you will likely have leaking brakes later.
To rotor clearance
