Power steering cap leak
Old May 22, 2023 | 08:31 PM
C3 4ME's Avatar
C3 4ME
Default Power steering cap leak
Has anyone else been through multiple power steering caps to finally find one that doesnt leak? My 79 has a parts store replacement pump, and parts store replacement cap (about the 5th one over the years). In the almost 18 years I've had my car I dont think the power steering has ever not leaked. It looks like this is the last leak to solve 🤞🤞. What have yall done to solve power steering cap leaks?
Old May 22, 2023 | 09:05 PM
l8279vette's Avatar
l8279vette
this is what I use 26095243
Old May 22, 2023 | 10:44 PM
C3 4ME's Avatar
C3 4ME
that cap fits on the factory power steering pump? when I put that number into google it looks like a totally different cap than what came on our 79's.
Old May 23, 2023 | 10:39 AM
sunflower 1972's Avatar
sunflower 1972
GM Part #7834183. Fits 1963 thru 1982.
Old May 23, 2023 | 10:46 AM
MelWff's Avatar
MelWff
Are you sure it's not overfilled? Should have a Cold line on the bottom of the cap stick.
Old May 23, 2023 | 12:10 PM
C3 4ME's Avatar
C3 4ME
I wish it were that simple! I think I'm going to try the GM part number listed and see what that gets me
Old May 23, 2023 | 12:38 PM
sunflower 1972
You must have a 1984 and up P/S pump reservoir. According to the google machine, that part number fits 1984 to 2002.
https://www.google.com/search?q=2609...t=gws-wiz#ip=1
SEVNT6's Avatar
SEVNT6
I bought my '76 new & it's still original.
Maybe the only thing that hasn't leaked in the P/S system is the cap...
Old May 23, 2023 | 12:40 PM
HeadsU.P.'s Avatar
HeadsU.P.
Try to find a 8 x 11 sheet of cork that is made for automotive. I found a sheet made by FelPro about 1/8" thick for making gaskets.
Somehow trace out the caps inside diameter, cut out with scissors and slip your new the cork gasket over the upside down cap and dipstick on your workbench.
Work the cork until you have a good fit. I may have RTV on it too. The cork stopped my leaky cap and now the cap fits super tight.
Old May 23, 2023 | 02:04 PM
MelWff's Avatar
MelWff
Do you have fluid around the center vent hole?
Old May 23, 2023 | 07:51 PM
C3 4ME's Avatar
C3 4ME
center vent hole? On the cap? I wasnt aware that there's a center vent hole. The fluid is definitely running from the top of the reservoir on down.
Old May 23, 2023 | 08:07 PM
BKarol's Avatar
BKarol
[QUOTE=C3 4ME;1606659759]center vent hole? On the cap? I wasnt aware that there's a center vent hole. The fluid is definitely running from the top of the reservoir on down.[/QUOTE
My 78 service manual addresses the problem.
"check oil level. If leakage persists with the level right and cap tight, replace the cap"
I have the old regular cap without any extra gaskets and no leaks.
Edit: Do have the hole in the bottom of the tube for which MelWff speaks. .
Old May 23, 2023 | 08:11 PM
Poolsharken's Avatar
Poolsharken
check for aeration of the fluid, meaning air bubbles or foam in the reservoir. This will cause fluid to push out of the reservoir via the cap. If this is the case, look for a leak on the return line.
Old May 23, 2023 | 08:12 PM
MelWff's Avatar
MelWff
Did you look at the bottom of the tube that goes into the fluid? There should be a hole going up the stem to the cap top.
Old May 24, 2023 | 09:49 AM
C3 4ME's Avatar
C3 4ME
thanks for clearing that up. I learned something today!
Old May 24, 2023 | 09:52 AM
C3 4ME's Avatar
C3 4ME
To Power steering cap leak
