350 L-82 Distributor Specs
Old May 24, 2023 | 06:33 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Default 350 L-82 Distributor Specs
Does anyone have the page out of the GM manual that showed all of the distributors and how much mechanical and vacuum advance they pull…..seen it here not long ago and it is buried in search he’ll….
1979 model year.
Jebby
Old May 24, 2023 | 06:50 PM
interpon's Avatar
interpon
Post 41
https://www.corvetteforum.com/forums...x-power-3.html
and it works fantastic in my l82 stick…
Old May 24, 2023 | 07:11 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Originally Posted by interpon
Post 41
Thanks a lot
It only pulls 16 degrees mechanical which is kinda short….but plan on running 230@.050 in this one so it will be fine with 20 degrees initial and add 10 for the vac…..30 total at idle which is only 3 more than the L-48 unit with a 12 degrees stop….
Great unit for large camshafts though! Too bad GM doesn’t sell this guy anymore…..
Jebby
To 350 L-82 Distributor Specs
