Fuse Panel Nut Missing?
Old May 26, 2023 | 08:45 PM
Viss1's Avatar
Viss1
Default Fuse Panel Nut Missing?
Went to reinstall the firewall side of the fuse panel harness and the bolt kept turning with no resistance. Took a closer look and it looks like there's no nut on the back of the interior side panel for the bolt to screw into. Am I an idiot or am I missing something?
Note: I may be an idiot whether or not something's missing.
Is there a nut missing from the hole in the middle?
Old May 26, 2023 | 10:19 PM
bmotojoe's Avatar
bmotojoe
It's possible that the press in insert nut has come loose.
You need to split the glass fuse portion from half that exits the firewall.
Disconnect battery if you haven't already done so.
Insert Nut:
