Think about your daily driver. We never or seldom raise the hood and start revving the throttle. Even if you could find the throttle.
Now lets look at your Vette. Likely the hood is up every week. A little tuning here. A little tuning there. Rev it some more. Play with the carb. More revs.
Plus you have a throttle cable pulling on the shaft bushings. Return springs pulling in another direction. It's a wonder the shaft bushing last as long as they do.
You have some play in the shaft. You have a couple of choices here. There is a throttle bushing repair kit at Summit. Comes with either four or eight bushings, drill bit, new shafts, etc. If you go this route, you really need a drill press and a rock steady hand. If you don't drill it perfect, you will be no farther ahead of the game.
Option 2. Buy a new base plate. Depending on what carb it's for, you may get an extra vacuum port included. That is always a bonus on these vacuum mobiles.
Update: On most carbs it's the primary shaft, drivers side bushing that gets the most abuse for obvious reasons. You said the whistle changes when you wiggle the shaft.
You will likely need to change at least the primary shaft bushings.
A whistle is usually caused by the carb base gasket. Snug the carb hold-down bolts a little and/or try replacing the base gasket.
Normally yes. But O.P. says, when he tinkers with the primary shaft the whistle comes & goes.
Thats what my "abused" Holley did with worn primary throttle shaft bushings.
