'68 Windshield Frame Lower Outer Corner Repair . . .
Old Jun 2, 2023 | 12:32 PM
FastCarsNMeanGuitars's Avatar
Default '68 Windshield Frame Lower Outer Corner Repair . . .
I have a 68 that has had the lower outer corners repaired with the available patch panels. This is the 73-82 patch that was used for the repair.
68-72 patches are not available ? I plan on doing fab work to weld in the appropriate finish metal to get the proper appearance. I would appreciate any insight on this. What about the hole, I never noticed it on the 73-82 cars. Thanks in advance for any input.
Old Jun 3, 2023 | 03:04 AM
If you scroll down towards the bottom , you can see Yogi Bairs lists the above pictured part (from Corvette Central) as a 68-82 Lower INNER Corner. So we have conflicting data.
http://www.bairscorvette.com/c3bodym...cagemetal.html
Here is a 68-82 Lower Inner from Zip Products Inc.
from https://www.zip-corvette.com/68-82-w...er-corner.html
https://www.zip-corvette.com/categor...-channels.html
Is it supply chain shortage, or businesses going under or the part has just never been made ?
Old Jun 3, 2023 | 04:49 AM
Shovels and Vettes's Avatar
Shovels and Vettes
I don't think it has ever been produced....and it makes no sense. THis is one of the most common pieces needed. I don't understand either, but I have never seen it available. I think there is one company making these type of components....I believe it CSC or something, I think I talked to the guy a few years ago about it....no good answer.
Old Jun 4, 2023 | 12:15 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Tim over at the Corvette Restoration site did this to his '71. Here's a link to part 1 of a 3 part series showing what he did...
https://www.corvette-restoration.com...orners-part-1/
Hope this helps
Paul
Old Jun 4, 2023 | 12:23 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Those Bairs items are definately OUTSIDE corners. Even though they're listed as 68-82, they are not quite exact replacements for the earlier models (68-71or72). To mate up properly with the lower center window frame, these pieces must be "built up" a bit on the ends inside of the hole (which wasn't present o n the early models.
This is how I understand it, but I'll admit I'm no expert...
To '68 Windshield Frame Lower Outer Corner Repair . . .
