Car pulling when downshifting
Old Jun 11, 2023 | 10:07 AM
KJLive's Avatar
KJLive
Default Car pulling when downshifting
I have a 69 Vette that I dont drive to often. I am far from being a mechanic, and was hoping someone may be able to provide some insight for me. When I downshift, it feels like the car is slightly pulling to one side. What would cause this issue? Otherwise, the car seems fine. Anything with the independent drive shafts at the rear? Very odd. Thank you!
Old Jun 11, 2023 | 11:12 AM
Tampa Jerry's Avatar
Tampa Jerry
It could be many things. Start with an under inflated tire, sticky brakes, cocked caliper piston or a clogged rubber brake line or a suspension and wheel alignment. Jerry
Old Jun 11, 2023 | 04:50 PM
Peterbuilt's Avatar
Peterbuilt
Take a close look at the front trailing arm bushings.
Old Jun 12, 2023 | 09:14 AM
gcb1966's Avatar
gcb1966
I had that issues on a C2. My issue was bad bushings in the trailing arms. As others have stated check the easy stuff first. Tires,brakes... Good Luck.
Old Jun 13, 2023 | 03:23 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Rear trailing arm bushings....
Jebby
Old Jun 14, 2023 | 04:48 PM
KJLive's Avatar
KJLive
Thanks everyone! I will check it out! One more question. Will I create additional issues if the car is driven prior to replacing the bushings?
Old Jun 15, 2023 | 08:25 AM
Tampa Jerry
If it's trailing arm bushings and or shims, it could make driving a challenge. If it's brakes or a bearing, it could be catastrophic. Why take the risk? Jerry
To Car pulling when downshifting
