A/C Question.
Old Jun 12, 2023 | 08:20 PM
rmrtrex's Avatar
rmrtrex
Default A/C Question.
I had everything with in reach replaced on my A/C system. Dryer, Orfice tube, new A/C hose to condensor, and new A/C compressor. They put some oil in the system and the rest freon. He was a certified A/C guy. Well it has now been 3 times that the freon comes out of the back of the compressor with pressure. Any Ideas? I think something is obviously clogged in my system, but what?
Old Jun 12, 2023 | 09:40 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
has it cooled since the rebuild?
That relief is usually set well over 400 psi
Neal
Old Jun 12, 2023 | 09:45 PM
rmrtrex's Avatar
rmrtrex
Neal
Nope because all the freon came out of backside of compressor. It came out with a lot of pressure and pretty much sprayed onto my valve cover.
Old Jun 12, 2023 | 10:00 PM
chevymans 77
Then yes, I would start with pulling the orifice tube and inspecting it for debris
Neal
Old Jun 12, 2023 | 10:02 PM
rmrtrex's Avatar
rmrtrex
Is there anyway to check condenser or evaporator for clog? I just want to be able to narrow it down, before I take it back to a/c guy. I can replace the condenser if I have to and maybe the evaporator.
Old Jun 13, 2023 | 07:28 AM
Mr D.'s Avatar
Mr D.
To check condenser or evaporator for clog you will need to disconnect the lines and use shop air to blow through it, also a good time to flush those two out to ensure they are clean. Your system is building up too much pressure on the high side and overcoming the compressor pressure relief valve.
Old Jun 13, 2023 | 10:34 AM
70s's Avatar
70s
Anytime I do an A/C job on an old car I do a solvent flush on all hard and soft lines plus the condenser and evap core. I do this to remove debris from the system, clean out old oils, etc. I don't know what has happened to the system over the vehicle's life and don't want to throw new parts and materials at the system only to ruin them. This also verifies all passage ways through these parts are open. Nitrogen or dried air can be used to check for clear lines too but if the system has an unknown history (I'm not the original owner and tech!) and I'm replacing the compressor due to failure (plus orifice and dryer with it of course) I prefer a proper flush. A/C flush solvent is only ~$25 a quart so its cheap insurance as far as I'm concerned. Cheaper than refrigerant.
Old Jun 14, 2023 | 07:04 AM
toylman's Avatar
toylman
You should say what year your car is first, but keep in mind that "rebuilt" does not always mean "working". If you look for information you will find that commercially rebuilt A/C compressors can be as reliable as other commercially rebuilt parts as carbs, alternators, starters, etc.
Getting beyond that and if it is determined your compressor is good. Take the advise given to have the system flushed out and replace the seals. Search youtube to see a flush being done by a shop. At the least you will have to replace the dryer. I don't think your shop did any basic trouble shooting or testing.
I had a stuck POA valve on a '72 system that prevented it from operating.
To A/C Question.
