1974 Convertible hard top stuck
Old Jun 17, 2023 | 05:27 PM
1974Stingray454's Avatar
1974Stingray454
3rd Gear
Default 1974 Convertible hard top stuck
Hello all,
I just purchased a 74 C3 convertible and the hard top is stuck. I have flipped the 3 levers on the front and I am twisting the release on the back however only the drivers and middle pins are releasing. Passenger side wont release. Any suggestions?
Thank you.
Old Jun 17, 2023 | 07:25 PM
Eliredandblack's Avatar
Eliredandblack
You will need to get a bright light and look at the rod that goes from the release handle to the chrome latch (located on the rear deck). The rod is bent on the latch end and on the handle end there is a small holder with a screw. I am guessing the rod is not being held by the small holder. Until you crawl in the back you won’t know for sure. Did you remove the special bolts that attach the hard top to the deck? The bolts are located on the read deck near your ears when you sit in the car.
Old Jun 17, 2023 | 07:34 PM
carriljc's Avatar
carriljc
1974Stingray454
yeah, don't go yanking on it. go make sure that the one side is "bolted in" instead of using a pin....
Old Jun 17, 2023 | 07:52 PM
1974Stingray454
3rd Gear
Got it, thanks for the reply's. I manually pulled on the rods to loosen and it popped. Looks like i need to take slack on out the line. Thanks!
To 1974 Convertible hard top stuck
