Starter motor teeth
Old Jan 18, 2003 | 04:21 PM
Teuffelhunde's Avatar
Teuffelhunde
Default Starter motor teeth
When replacing a starter motor is there anything special to be done to allign the teeth of the starter with the flywheel? I'm cranking my engine and I think the noise I'm hearing is the teeth knocking together. It's not a grinding sound though. Any ideas?
Old Jan 18, 2003 | 05:56 PM
cchristo's Avatar
cchristo
Default Re: Starter motor teeth (Teuffelhunde)
Same thing happened to me when I replaced my starter recently. Sometimes it would work fine, others, I'd get a noise similar to what you describe. A few days later, while sweeping the floor, I found a shim that I had forgotten to put in between the starter and the block. Put the car on the ramp, loosened up the starter bolts (didn't have to take it all the way off),put the shim back in and no more problems.
Old Jan 19, 2003 | 10:00 AM
Teuffelhunde
Default Re: Starter motor teeth (cchristo)
ttt
To Starter motor teeth
