trans oil?
Old Jun 20, 2023 | 09:39 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Default trans oil?
Where would I check the oil level on a 4 speed and where would I add if low.?
Old Jun 20, 2023 | 10:34 PM
Bikespace's Avatar
Bikespace
The same advice as changing it. Unscrew the top fill port with the car raised and LEVEL. You should get no more than a dribble. If none comes out, fill at that port. You may need a hand pump (I bought one that mounts right on the jug).
The danger is when you change the fluid, If you can get the bottom drain port out, but not the fill port, you've now disabled your car, so unscrew the fill port first.
On a B&W Super T-10, the plugs are square-heads, so you need a 12-point wrench.
Old Jun 21, 2023 | 03:45 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Or, you could use the correct square socket.
Yes you can purchase the correct tool.
Old Apr 4, 2024 | 04:37 PM
AZSP33D's Avatar
AZSP33D
I’ve used the 10W60 shell supercar oil, drained after 2000 miles, no gold flakes and it looked new. Shifted excellent and fast behind the 6,500 rpm engine, fun to drive transmission for sure… and sold the trans to ZF Doc. He said it was perfect inside, just needed consumables, most of it ended up in a ZR1 in Germany.
Removed from a 1993 donor, black tag (meaning German manufactured) but helical cut gears as many 1993 had. Used it for autocross and a little bit of open track, removed it to install a new Tremec TKX Silver Sport kit.
I did have excessive wear on the clutch and flywheel especially for the low amount miles, but that’s mostly from aggressive starts with perhaps a little more torque than it may have been designed for.
But — After reading some of the horror stories, where I’m not sure what the real cause is, I would likely use syncromesh if I had to do it again.
Old Apr 4, 2024 | 06:27 PM
kanvasman's Avatar
kanvasman
I usually just remove the fill plug, put my finger in it and if I can feel the oil, it's good to go. but I am just an old guy who doesn't know any better than to be careful where you put your fingers....
Old Apr 5, 2024 | 10:31 AM
MelWff's Avatar
MelWff
the transmissions used in a C3 use a 75W90 oil, definitely not a 10W60.
Old Apr 5, 2024 | 10:39 AM
AZSP33D's Avatar
AZSP33D
Originally Posted by MelWff;[url=tel:1607689585
1607689585[/url]]the transmissions used in a C3 use a 75W90 oil, definitely not a 10W60.
good catch, I was replying to the wrong thread (this was the one that shows up at the bottom for “similar threads”)
To trans oil?
