New A/C conversion.
Old Jun 27, 2023 | 08:22 AM
electrocreep's Avatar
electrocreep
Cruising
Default New A/C conversion.
Hi guys. Got my 1982 CE Corvette a few weeks back (and running the other day). The
freon is completely gone, and I want to know if anyone out there has done the conversion to the new stuff...and what it cost to do. Thanks!
Old Jun 27, 2023 | 08:55 AM
interpon's Avatar
interpon
nice! pics of your new ride?
well assuming we have no clue what is wrong with system.or what was is in there. i may be inclined to first check for leaks (use clean compressed air) and the orifice screen for metal..even run ac clutch bypass for a couple seconds to see if it sounds normal..
conversion at minimum IMO
- new accumulator
- flush system (not compressor if good)..
- all new o rings
- new slightly smaller orifice for 134
- use gauges and correct oil charge and fill to about 80% of R12 load
optional
- new condenser
- sanden compressor upgrade ?
- new rubber hoses
Old Jun 27, 2023 | 09:01 AM
electrocreep
Cruising
Old Jun 27, 2023 | 09:48 AM
Stormin_Normin's Avatar
Stormin_Normin
- new accumulator
- all new o rings
optional
- new condenser
- new rubber hoses
^ this is about it.
I converted mine to a Sanden 709 rear port compressor using an Alan Grove bracket. But that’s not necessary.
You can get a set of gauges and vacuum pump for about the cost of a service anymore.
Old Jun 27, 2023 | 01:53 PM
wwiiavfan's Avatar
wwiiavfan
It’s probably worth your time to pull the evap housing apart and clean it out. No sense pouring a bunch of time & money into the original system only to have the already weak airflow hampered by an evap clogged with leaves, dirt, bugs, and who knows what else.
I was where you are, didn’t know the condition of any system components, and, figuring I’d be headed down a rabbit hole, just decided to go with a known entity and convert to Vintage Air. $2k in parts and a couple weekends of my time, and I have solid cold A/C on a 52 year old car.
Oh, and my original evap was indeed clogged with crap.
Old Jun 27, 2023 | 05:05 PM
carriljc's Avatar
carriljc
I've done conversions on several vehicles and in different manners:
1989 Nissan Pickup-- cleaned and flushed, replaced O-rings, replaced control valve, Did it pretty much by the book, did not replace hoses per reports they will work fine....and they have....for years and years.
~1995 Toyota Land Cruiser. Friends just wanted to swap over to R-134a since it was essentially empty (but still sealed). Bought adapter fittings and R-134a, evacuated, and charged. Dammm!! It worked as well my Nissan. I was surprised.
1990 Ford Bronco: Replaced Orifice valve, flushed, did O-rings. Worked quite well..... not as well as the Nissan Pickup or the Toy Land Cruiser but adequately cooling to the low 40s.
1968 Corvette. I installed aftermarket a/c from Hot Rod Air. Worked just fine. About 10 years later I replaced the Condenser to squeeze in the biggest one I could in front of the radiator. It already cooled to below 40°, and still does..... just seemed to get there quicker. Can't hurt and the Condenser was relatively cheap so I was glad I did it. While I had it empty I also installed a Trinary Switch to all my elec fan not to have run when at speed.
SO- depending on how you much effort you want to put in you can try just doing a fittings swap, evacuate, and recharge (hopefully it has not been open corroded?) and see how it performs. You can then make a decision on repairing yours or getting Vintage A/C which has a pretty good reputation on this forum.
Old Jun 27, 2023 | 08:21 PM
The Grinch's Avatar
The Grinch
I will be going down this road myself over the winter. My old friend kept his R-12 system and used a can tap to fill it with keyboard cleaner. He swore by it.
To New A/C conversion.
