I have a 69 MKIV 427 with edelbrock 60499 aluminium heads out of a 69 corvette. Do you recommend drilling the extra two holes in each side of the block? Will it help cooling the engine temp? If so, which head gaskets should I use (1017, 1027, 1037)?
