Simple brake light question
Old Jul 3, 2023 | 02:30 PM
Xtian Ruiz's Avatar
Xtian Ruiz
Default Simple brake light question
One brake light comes on but the other side does not I’ve changed all bulbs and checked fuse and to no avail it doesn’t work. Thoughts?
Old Jul 3, 2023 | 04:54 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
do you have, test light, meter, anything to check wires?
Old Jul 3, 2023 | 06:13 PM
Mooser's Avatar
Mooser
corvette = ground problem
Can't tell the year you're working on but first, check the power going to the power pin on the light socket, then check for continuity of the socket sides to ground.
M
Old Jul 3, 2023 | 10:26 PM
Xtian Ruiz's Avatar
Xtian Ruiz
Can’t check no voltmeter I’ll check all grounds tho it’s weird tho because the tail light stays on but when the brakes pressed only the left side stays dark the right side is bright
Old Jul 3, 2023 | 10:31 PM
walleyfisher's Avatar
walleyfisher
Check your turnsignal switch
Old Jul 3, 2023 | 10:44 PM
Xtian Ruiz's Avatar
Xtian Ruiz
Is this typically a culprit for these issues. And how do I tell it’s bad
Old Jul 3, 2023 | 11:22 PM
Peterbuilt's Avatar
Peterbuilt
Take a wire and attach it to a good ground, and touch the other end of the wire to the brass part of the bulb holder.
If the bulb light up you may have a bad socket.
Old Jul 3, 2023 | 11:25 PM
walleyfisher
have somebody stand behind your car (with it turned off) then step on the brake peddle and jiggle the turnsignal switch and see if the other brake light comes on
Old Jul 4, 2023 | 12:11 AM
Avispa's Avatar
Avispa
Yes, this is a likely culprit. Check if the RH turn signal works. If it does, your problem is in the switch.
Old Jul 4, 2023 | 12:34 AM
Xtian Ruiz's Avatar
Xtian Ruiz
by switch you mean the one in the fuse box yes not the physical one for turning the signal on lol
Old Jul 4, 2023 | 06:31 AM
stevedinino's Avatar
stevedinino
Originally Posted by Xtian Ruiz;[url=tel:1606802352
1606802352[/url]]Is this typically a culprit for these issues. And how do I tell it’s bad
Start simple- check to see if you left the turn signal switch up or down the last time you parked. If it’s on, the brake light on one side won’t come on. That’s the design.
I once spent an hour trying to track down this exact problem until I stumbled on the turn signal. Centered the switch, problem fixed.
To Simple brake light question
