HEI distributor hits intake
Lars
V8FastCars@msn,.com
Correct installation:
Jebby
Note vacuum hose to vac can. And covers over the distributor. Hard to get a good look at the distributor orientation with the covers on. And this thread is about the orientation of the distributor. The only time my covers are off is when it's being worked on.
Lars
If rebuilt, it is possible to reinstall distributor gear 180 degrees off. This will often generate OP's problem.
You want "dimple" on gear and rotor tip to be on same side of shaft.
Link below:
Mapman
https://www.corvetteforum.com/forums...ientation.html
Left distributor gear has large "dimple" - just below "Pin" in "Spring Pin". Right distributor gear has quite small "dimple" up 45 degrees from "?" in "Dowel Pin?".
Right distributor is from an early SBC around 1957 - pin was swedged in place.
Any distributor can be clocked in any position the owner (or OP) wants, PROVIDED the plug wires correctly line up with that clocking.
Distributor/engine don't care.
CONVENTION is to "make it square" in the engine bay as in reply #1. Electrical plug 90 degrees from the front of the car, vacuum pot facing maybe 7 o'clock
Which puts the #1 plug tower at ABOUT a 5 O'clock position.
This avoids the problem you've got of the HEI disty hitting things. Yours appears to be clocked one plug /tower counter-clockwise.
Start with a piece of chalk by marking 0 degrees on your harmonic balancer -- just to make it easier to see. You don't need a timing light, a flashlight will do.
Pull spark plug #1 (driver's side, front), put your thumb over the hole, and crank until compression begins to blow your finger off the hole.
That's how you know you're on the compression stroke, and not 180 out. On some engines you can put a drinking straw in the plug hole and watch the piston push it up.
Well, before they made straws illegal, you could /s
You can crank or you can simply turn the crankshaft using a long wrench and the bolt on the front of the motor. It's easy to go past TDC if you
do it by cranking, and you can't (or don't want to back up).
Confirm you're at or near TDC by looking for the mark on the harmonic balancer. Go around again if necessary.
Take the cap off the HEI rotate the rotor as necessary, and stab the distributor so the rotor lines up with the #1 tower on the HEI cap. Disty will usually sit about 1/4" above its base.
Firing order is 1 8 4 3 6 5 7 2
Gently push the disty down as you crank a little more until the oil pump drive seats and the disty goes all the way down .
Replace the plug, gently tighten the disty hold down, see if it starts. If it doesn't, you're probably 180 out. Or failed to hook up power to the distributor (sheepish grin...)
On the other hand, if it starts right up, get out the timing light and set yer base timing, with the vacuum line disconnected from the disty and plugged. (so no vacuum leak!)
I just got done doing this, stabbing a HEI to replace a decrepit Mallory distributor. Want me to tell you all the WRONG ways you can do it? LOL I hadn't stabbed a disty in...DECADES!
The one GOOD thing about stabbing a distributor 180 degrees out is that NO cylinder will fire. You crank and get absolutely NOTHING. That's when .... YOU KNOW!
It' doesn't do that horrible thing like when you've got a couple of plug wires reversed, backfiring through the manifold, etc.
One other thing. If you've got a disty with a mechanical tachometer drive, you do not ABSOLUTELY have to buy a HEI with a mechanical drive.
You can buy a doo-dad that converts your tachometer to electronic. Now would be a good time! Great! Just another project, pull the dash, AMIRIGHT???
https://corvetteparts.com/item/conve...onic-1965-1974 $170
Cheers!
You can easily twist the distributor body 20 degrees to obtain your desired timing.
But yes, you could stab it on the NEXT tooth (position, alignment, whatever) , and twist it 16 degrees the OTHER way.
I "ran out of twist" on my old distributor because the tachometer drive hit something. Couldn't advance the timing as much as I wanted. The solution was, as you suggest, to restab it one tooth off and twist the other way.
When I purchased the car the timing was horribly retarded. What a pleasant surprise to get it where it should have been and instantly get another 30-40 horsepower (or more) , FREE!
Saw the EXACT SAME THING on some TV show about restoring classic cars, '68 with poor performance due to retarded timing. I'm sure someone remembers the show and the episode. I was like.... are these guys reading my mind? Same color car as mine, too!
Replacing an old Mallory with a "generic" HEI disty in a few days ago, WHAT AN IMPROVEMENT! Starts instantly, idles much lower/ smoother, and.. I could swear it's making more power than ever. It sounds different, especially at cruise The Mallory did NOT have vacuum advance.
