C3 corvette tune up
Old Jul 18, 2023 | 02:05 PM
TrixieC3's Avatar
TrixieC3
1st Gear
Default C3 corvette tune up
I just bought a 1973 corvette that's been sitting in a barn for 3 years. Im wondering if anyone could point me in the right direction of the parts I need for a tune up and where I could buy those at.
Old Jul 18, 2023 | 02:42 PM
mortgageguy's Avatar
mortgageguy
Points, condenser, rotor, distributor cap, plugs, spark plug wires. I highly recommend NAPA for ignition parts.
Old Jul 18, 2023 | 03:18 PM
rmrtrex's Avatar
rmrtrex
You might want to add draining old gas from the fuel tank and possibly changing Tranny and Diff fluid.
Old Jul 19, 2023 | 08:38 AM
cottoneg's Avatar
cottoneg
Don't forget the brakes! I would flush the system with new brake fluid. Since it sat for 3 years, check the calipers for leaking. The old fluid absorbs moisture and may have pitted the inside of the caliper.
Also, check the tires for hardness and cracks. I think most tires have a date code. See how old they are. Hard rubber will make your Corvette feel like its on ice.
Old Jul 19, 2023 | 10:41 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Why don't you determine if it needs a tune up first.......? 3 years is not a long time to sit.......I have started cars that sat much longer with no issues.......check the oil...fresh gas and let er rip......if it doesn't run well, assess that situation at that time.....
My 82' Z/28 sat in my brothers polebarn for 12 years and it fired right up with fresh gas.......the carb needed a rebuild, and that is probably what you should consider spending your money on......
Jebby
Old Jul 19, 2023 | 12:50 PM
Alwyn678's Avatar
Alwyn678
[QUOTE=cottoneg;1606852686]Don't forget the brakes! I would flush the system with new brake fluid. Since it sat for 3 years, check the calipers for leaking. The old fluid absorbs moisture and may have pitted the inside of the caliper
Exactly.....Caliper pitting happened to me. Replacing/Rebuilding all four calipers now.
To C3 corvette tune up
