Rear spring install problems
Old Jul 22, 2023 | 12:07 PM
1967droptop's Avatar
1967droptop
Default Rear spring install problems
UPDATE: Problem resolved. Thanks for the suggestions
Attempting to install the rear spring in my 1973. Have read several posts and attempted the method that suggests using a c clamp, block of wood and jacking the spring up until the bolt protrudes far enough to get the rubber bushing, washer and nut in place. This is a complete car with the original 9 leaf spring. Any advice is appreciated. The problem I’m having is that before the spring compresses enough to install the hardware, the car raises up and I can’t install the hardware. Thanks.
Old Jul 22, 2023 | 12:14 PM
Crimson Thunder's Avatar
Crimson Thunder
The way you described it is exactly how you do it. The original 9 leaf spring compresses easily.
Old Jul 22, 2023 | 12:27 PM
1967droptop
Thanks for your response. I failed describe the problem… distraction. I have since edited the original post. Thanks.
Old Jul 22, 2023 | 09:56 PM
interpon's Avatar
interpon
Pics of where jack point is?
go further out to the end..
Old Jul 22, 2023 | 10:47 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
You do have to prop up the trailing arm level at approx normal ride height. Stuff doesn't line up unless you do.
Are you only jacking up one side of the spring at a time? There should be more than enough weight there to do that.
A picture might help us help you.
Old Jul 23, 2023 | 12:43 AM
69L88's Avatar
69L88
I use a rubber sanding block between the jack pad and the spring. This keeps the spring from slipping on the jack pad. Orient the jack parallel to the spring so the jack can move while you raise the spring.
To Rear spring install problems
