ISO C3 Ashtray Light Socket
Re: 1973 C3
Hi gurus, I've been looking for a new socket for the light bulb that illuminates the ashtray.
The wire pulled out of the socket and I'm not sure if it can be repaired?
Look for a Dornan 85805 at your local parts store.... you might be able to swap in the lead from it....the insulator just might be small enough and if not then you might be able to keep the lighter housing insulator washer and just use the lead from the 85805.
For that matter, if the insulator washer is good you can just buy and single lead socket whose lead will fit through the lighter lamp housing hole.
https://www.ebay.com/itm/30431297583...75.c101224.m-1
