Engine dies at full throttle
Old Aug 5, 2023 | 01:41 PM
Ponziniman's Avatar
Ponziniman
5th Gear
Default Engine dies at full throttle
My first post. I need some input on this issue. 1971 Corvette, Blueprint 383 stroker 420hp, Brawler 650cfm carb (new carb 1 year), 700r4 trans. Recently had it tuned up with a new at cable added as it wasn't shifting properly. Testing at different acceleration speeds it worked fine until from a rolling speed of 5 mph I romp on it! It was pulling great up to about 60 and then dies completely. Put it in neutral and start it up while rolling, back in gear, with a little hesitation takes off again. A short while later I do it again and the same results. Drove back to the mechanic and explained what happened and he is thinking something electrical. I am thinking fuel. This is probably not enough information but....what do you think? All input welcome.
Old Aug 5, 2023 | 03:52 PM
REELAV8R's Avatar
REELAV8R
I agree with you sounds like it's running out of fuel. A 650 cfm carb on a 383? Dual plane intake or single?
Old Aug 5, 2023 | 05:54 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
whats your fuel pressure
Old Aug 5, 2023 | 06:10 PM
Ponziniman's Avatar
Ponziniman
5th Gear
I believe it is a dual plane.
Old Aug 5, 2023 | 06:22 PM
Ponziniman's Avatar
Ponziniman
5th Gear
I have it regulated at 7-7.5 psi
Old Aug 5, 2023 | 06:45 PM
REELAV8R's Avatar
REELAV8R
7 psi should be more than enough. But if it's a clogged sock or filter or pump problem then the pressure likely drops off during use. Not part of your problem, a 650 cfm carb for a 383 may be a bit small. 750 would be better.
Old Aug 5, 2023 | 07:10 PM
OMF's Avatar
OMF
If you've got a gauge on the fuel line, set up your camera somehow.... focused on the gauge.....then go do your 0-60 MPH fun again and see if the pressure gets low. That should give you a direction to follow
BTW....welcome to the forum!
Old Aug 5, 2023 | 07:28 PM
Ponziniman's Avatar
Ponziniman
5th Gear
I have a feeling you are right about the size of the carb. I was thinking fuel economy when I bought it. Not what I need when it's fun time!
Old Aug 5, 2023 | 10:02 PM
kkupec02's Avatar
kkupec02
welcome
Old Aug 6, 2023 | 12:44 AM
n2h2o2's Avatar
n2h2o2
The Blueprint website has the same engine available dressed with a 750...
Holley 4150 is the way to go with this one...
Old Aug 6, 2023 | 08:27 AM
pspicci's Avatar
pspicci
750 might be a better crb size but the 650 is not the reason the engine is dying at full throttle unless there is something defective in the carb
Pat
Old Aug 6, 2023 | 08:50 AM
Rescue Rogers
What are your float bowl levels set too? maybe get a little more fuel in there, maybe you are sucking them dry and they arent refilling fast enough?
Old Aug 6, 2023 | 09:30 AM
n2h2o2's Avatar
n2h2o2
I was thinking the small accelerator pump on the 650 might starve the 383 as it winds up...
I seem to remember some smaller Holleys having a stumble from idle to full throttle when you stomped it...
But if it is stumbling at full throttle while running at highway speeds. it could be fuel delivery problem or it could be the spark is not advancing...
OP says he is at idle and then stomps on it...Could try adjusting the accelerator pump on the 650 to see if that solves the problem...
Old Aug 6, 2023 | 10:55 AM
Rescue Rogers
He gets all the way to 60 beforebit dies, accelerator pumps just provide an extra squirt to supplement the throttles going full open and not having enough fuel forbthat bigbgulp of air...it would bog or go very lean on transition if it was the pump.
Having an AFR gauge would help
Old Aug 6, 2023 | 05:42 PM
Ponziniman's Avatar
Ponziniman
5th Gear
I had a Fast EZ EFI prior to the Brawler. Never had this problem. I will look into the float bowls and an AFR gauge before I switch out the carb.
Old Aug 6, 2023 | 06:51 PM
Rescue Rogers
Is your tank vent clear? IF the vent is plugged and you take a huge pull on it, it cant get gas....try opening the gas cap and take it for a quick romp....I had a motorcycle waaaaay back that had a vent issue and it would die until I openned the gas cap
To Engine dies at full throttle
